简介
Use this guide to replace a faulty Black and Decker Pivot MAX (Model BDH2000PL) Motor.
The motor is responsible for rotating a fan which creates suction. The motor is the only component that causes motion while running and thus it is the only source of producing any potential noise issues. If the motor is making unusual noise, then it probably has a bad bearing or a damaged impeller. If your device is fully charged and turns on but does not run at all, check for any potential clogs. If nothing is clogged, the motor is likely the issue.
It is recommended that before replacing the motor, ensure the battery and internal wiring is not the damaged. If needed, follow this link to find instruction for replacing the battery. If everything looks fine and the device still does not run, follow this guide to replace the motor.
Make sure to power off your device and disconnect from any external power source prior to beginning this guide.
你所需要的
Press in and hold the release button.
Rotate the dust filter chamber counter-clockwise.
Remove the dust filter chamber.
另外一个人完成了本指南。
2条评论
Unbelievable! They sell a replacement motor but not replacement batteries! Wow!
