跳转到主内容
Black and Decker Pivot MAX Battery Replacement
你所需要的
  1. Black and Decker Pivot MAX Battery Replacement, Battery: 步骤 1 中的图像 1,2 Black and Decker Pivot MAX Battery Replacement, Battery: 步骤 1 中的图像 2,2
    • Press in and hold the release button.
    • Rotate the dust filter chamber counter-clockwise.
    • Remove the dust filter chamber.
  2. Black and Decker Pivot MAX Battery Replacement: 步骤 2 中的图像 1,1
    • Remove the two 10 mm screws from the motor casing with a Phillips #1 screwdriver.
  3. Black and Decker Pivot MAX Battery Replacement: 步骤 3 中的图像 1,1
    • Pull the battery cover up and then slide it away from the motor to remove.
  4. Black and Decker Pivot MAX Battery Replacement: 步骤 4 中的图像 1,1
    • Remove the battery unit by pulling it out of the main body.
  5. Black and Decker Pivot MAX Battery Replacement: 步骤 5 中的图像 1,1
    • Disconnect the quick connect wire harness that connects the motor and battery located in the battery storage compartment.
结论
25等其他人完成本指南。
Jesse Sipes
于11/06/17注册
586 声望
创作了2篇指南
团队
IUPUI, Team S5-G6, Baechle Fall 2017 IUPUI, Team S5-G6, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S5G6
3 名成员
创作了5篇指南
27条评论
any idea where to find the replacement battery? Does it come as a unit or do you need to disassemble the battery pack and replace the cells?
DMcDermott - 回复
Where do I get the cells to replace the old ones?
Patricia Leat - 回复
How do you disconnect the quick connect
DJ SmashBeatz - 回复
My battery pack is soldered to a circuit board. There is no quick connect. (Model BDH2000PL, Type 2).
HBL - 回复
Same here. Worst design ever.
James Watson -
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 133
过去 30 天: 591
总计 45,978
