跳转到主内容
Black and Decker PS1800 Transmission Replacement
你所需要的
  1. Black and Decker PS1800 Transmission Replacement, Open the Outer Drill Case: 步骤 1 中的图像 1,2 Black and Decker PS1800 Transmission Replacement, Open the Outer Drill Case: 步骤 1 中的图像 2,2
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Black and Decker PS1800 Transmission Replacement: 步骤 2 中的图像 1,1
    • Separate the outer drill case to expose the components and switch.
  3. Black and Decker PS1800 Transmission Replacement, Disconnect Motor: 步骤 3 中的图像 1,3 Black and Decker PS1800 Transmission Replacement, Disconnect Motor: 步骤 3 中的图像 2,3 Black and Decker PS1800 Transmission Replacement, Disconnect Motor: 步骤 3 中的图像 3,3
    • Locate the motor at the top left hand corner.
    • Carefully disconnect the red and black wires attached to the motor.
  4. Black and Decker PS1800 Transmission Replacement: 步骤 4 中的图像 1,1
    • Unscrew the motor from the drill's transmission.
    • Detach the transmission carefully, ensuring that the gears remain intact.
  5. Black and Decker PS1800 Transmission Replacement: 步骤 5 中的图像 1,2 Black and Decker PS1800 Transmission Replacement: 步骤 5 中的图像 2,2
    • Remove the motor from the transmission assembly, as pictured.
  6. Black and Decker PS1800 Transmission Replacement, Transmission: 步骤 6 中的图像 1,3 Black and Decker PS1800 Transmission Replacement, Transmission: 步骤 6 中的图像 2,3 Black and Decker PS1800 Transmission Replacement, Transmission: 步骤 6 中的图像 3,3
    • Unscrew the torque adjuster from the transmission by removing the screws highlighted in the lefthand picture.
  7. Black and Decker PS1800 Transmission Replacement: 步骤 7 中的图像 1,1
    • Align the new transmission gears with the motor’s gears.
    • Reattach the transmission and motor by rescrewing the initial screws.
  8. Black and Decker PS1800 Transmission Replacement: 步骤 8 中的图像 1,2 Black and Decker PS1800 Transmission Replacement: 步骤 8 中的图像 2,2
    • Reconnect the torque adjuster to the transmission by following the procedure seen in step 6.
  9. Black and Decker PS1800 Transmission Replacement: 步骤 9 中的图像 1,1
    • Reconnect black and red wires onto the motor and place the motor, transmission and torque adjuster back onto their initial location.
  10. Black and Decker PS1800 Transmission Replacement: 步骤 10 中的图像 1,1
    • Reconnect the clamshell.
    • Press trigger to make sure the new transmission works.
    • Press and hold the clam-shell to assure it will not drop while testing.
结论
David Nawl
于10/19/16注册
279 声望
创作了2篇指南
团队
IUPUI, Team 2-3, Baechle Fall 2016 IUPUI, Team 2-3, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S2G3
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 14
总计 1,471
