跳转到主内容
简介
This guide will illustrate how to open the outer case of the Black and Decker PS1800.
配件
没有特定配件。
  1. Lay the drill on its side, assuring that the screw holes are facing upwards. Remove seven 12 mm  screws using a Phillips #00 screwdriver.
    • Lay the drill on its side, assuring that the screw holes are facing upwards.
    • Remove seven 12 mm screws using a Phillips #00 screwdriver.
  2. Separate the outer drill case to expose the components and switch.
    • Separate the outer drill case to expose the components and switch.
结论
另外一个人完成了本指南。
Christian Aldrich
于2016年10月12日注册
223 信誉积分
创作了2篇指南
团队
IUPUI, Team 2-3, Baechle Fall 2016 IUPUI, Team 2-3, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S2G3
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 1
总计 124
