跳转到主内容
Black and Decker LI4000 Outer Casing Replacement
你所需要的
  1. Black and Decker LI4000 Outer Casing Replacement, Outer Casing: 步骤 1 中的图像 1,3 Black and Decker LI4000 Outer Casing Replacement, Outer Casing: 步骤 1 中的图像 2,3 Black and Decker LI4000 Outer Casing Replacement, Outer Casing: 步骤 1 中的图像 3,3
    • Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
  2. Black and Decker LI4000 Outer Casing Replacement: 步骤 2 中的图像 1,1
    • Remove all six of the 12-mm long case screws with a Philips #1 Screwdriver. These screws can be found on the side of the LI4000 with the "Warning" sticker.
  3. Black and Decker LI4000 Outer Casing Replacement: 步骤 3 中的图像 1,2 Black and Decker LI4000 Outer Casing Replacement: 步骤 3 中的图像 2,2
    • Remove the two screws that are 4-mm Hexagonal #2.5. These are very small case screws that can be found underneath the two stickers from Step 1.
  4. Black and Decker LI4000 Outer Casing Replacement: 步骤 4 中的图像 1,2 Black and Decker LI4000 Outer Casing Replacement: 步骤 4 中的图像 2,2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry on the seam as shown with a Spudger, in order to get the top casing loose.
    • Pull the two sides apart while making sure the side that you are removing is the one with all of the case screw holes.
    • It is good practice to remove the top connection of the battery as shown in the third image, as this will be the first step to replacing any of the components for this screwdriver.
结论
Bryan Beard
于02/11/16注册
107 声望
撰写一个指南
团队
IUPUI, Team 2-3, Baechle Spring 2016 IUPUI, Team 2-3, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S2G3
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 25
总计 337
