跳转到主内容
Black and Decker LI4000 Battery Replacement
你所需要的
  1. Black and Decker LI4000 Battery Replacement, Outer Casing: 步骤 1 中的图像 1,3 Black and Decker LI4000 Battery Replacement, Outer Casing: 步骤 1 中的图像 2,3 Black and Decker LI4000 Battery Replacement, Outer Casing: 步骤 1 中的图像 3,3
    • Remove the stickers found on the bottom and sides of the LI4000, using a spudger.
  2. Black and Decker LI4000 Battery Replacement: 步骤 2 中的图像 1,1
    • Remove all six of the 12-mm long case screws with a Philips #1 Screwdriver. These screws can be found on the side of the LI4000 with the "Warning" sticker.
  3. Black and Decker LI4000 Battery Replacement: 步骤 3 中的图像 1,2 Black and Decker LI4000 Battery Replacement: 步骤 3 中的图像 2,2
    • Remove the two screws that are 4-mm Hexagonal #2.5. These are very small case screws that can be found underneath the two stickers from Step 1.
  4. Black and Decker LI4000 Battery Replacement: 步骤 4 中的图像 1,2 Black and Decker LI4000 Battery Replacement: 步骤 4 中的图像 2,2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Pry on the seam as shown with a Spudger, in order to get the top casing loose.
    • Pull the two sides apart while making sure the side that you are removing is the one with all of the case screw holes.
    • It is good practice to remove the top connection of the battery as shown in the third image, as this will be the first step to replacing any of the components for this screwdriver.
  5. Black and Decker LI4000 Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Locate the battery. The cardboard covered cylinder is the rechargeable battery.
  6. Black and Decker LI4000 Battery Replacement: 步骤 6 中的图像 1,2 Black and Decker LI4000 Battery Replacement: 步骤 6 中的图像 2,2
    • Detach the contact by pulling the contact away from the battery.
  7. Black and Decker LI4000 Battery Replacement: 步骤 7 中的图像 1,2 Black and Decker LI4000 Battery Replacement: 步骤 7 中的图像 2,2
    • Gently lift the end of the battery out of the plastic casing
  8. Black and Decker LI4000 Battery Replacement: 步骤 8 中的图像 1,1
    • Locate the other contact on the rear side of the battery.
  9. Black and Decker LI4000 Battery Replacement: 步骤 9 中的图像 1,2 Black and Decker LI4000 Battery Replacement: 步骤 9 中的图像 2,2
  10. Black and Decker LI4000 Battery Replacement: 步骤 10 中的图像 1,1
    • To install a new battery, repeat the steps in reverse order with a new battery.
结论
17等其他人完成本指南。
团队
IUPUI, Team 2-3, Baechle Spring 2016 IUPUI, Team 2-3, Baechle Spring 2016 的会员
IUPUI-BAECHLE-S16S2G3
3 名成员
创作了8篇指南
5条评论
Anyone know what type of battery this is so I can replace it?
Thanks
Brian
Brian Wong - 回复
If you peel off the paper of the battery, you will find out that it is a 18650 Lithium battery. Mine has US18650VT T11250 label. It seems from SONY.
River Seow - 回复
When looking for a replacement battery, see if you can find one with solder tabs opposite to each other. The internal plastic housing of the battery is made exactly for two tabs opposing each other; I had to cut the plastic here and there to make my battery (with both tabs at the same side) fit.
Xian Lu - 回复
New one is cheaper than a new battery
Wolfie Shay - 回复
new battery costs 10$, its a 18650 or LI4000
GEEnius - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 16
过去 30 天: 107
总计 11,160
