跳转到主内容
Black and Decker LDX172C Battery Charge Port Replacement
你所需要的
  1. Black and Decker LDX172C Battery Charge Port Replacement, Battery Charge Port: 步骤 1 中的图像 1,1
    • Before beginning, make sure the motor direction switch is in the neutral position.
    • Place the drill on the work surface with the chuck facing downward. Locate and remove the two #2 X 10mm Phillips screws located right of the motor.
  2. Black and Decker LDX172C Battery Charge Port Replacement: 步骤 2 中的图像 1,1
    • Rotate the drill to it's left side - the chuck should be facing to the right. Locate and remove the eight #2 X 5mm Phillips fasteners from the body of the drill.
  3. Black and Decker LDX172C Battery Charge Port Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the right half of the body from the drill.
    • The trigger mechanism is spring loaded and may eject from the drill when the body is removed.
    • Locate the battery charging port in the base of the drill.
  4. Black and Decker LDX172C Battery Charge Port Replacement: 步骤 4 中的图像 1,1
    • Remember that the battery may still have a charge. To avoid electrical shock, it is a good idea to disconnect the battery before modifying any connections on the charging port. You can find how to disconnect the battery here
    • Remove the soldered wire connections as marked.
    • Re-solder the wire connections to the new charge port and insert the charge port back into its proper location.
    • Repeat steps in reverse to reassemble.
结论
2等其他人完成本指南。
Eric Miessen
于02/13/16注册
182 声望
撰写一个指南
团队
IUPUI, Team 3-3, Wilson Spring 2016 IUPUI, Team 3-3, Wilson Spring 2016 的会员
IUPUI-WILSON-S16S3G3
4 名成员
创作了6篇指南
一条评论
Hi where can I get the replacement charge port from. Thanks
adam mellor - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 33
总计 2,466
