跳转到主内容
Black and Decker LDX 120C Gear Replacement
你所需要的
  1. Black and Decker LDX 120C Gear  Replacement, Outer Case: 步骤 1 中的图像 1,1
    • For this guide we will need to use a 1.0 mm phillips #1 screw.
    • There are a total of thirteen screws that need to be removed in order to open the drill and access the interior components.
  2. Black and Decker LDX 120C Gear  Replacement: 步骤 2 中的图像 1,1
    • Remove the four screws on the back top side of the drill.
  3. Black and Decker LDX 120C Gear  Replacement: 步骤 3 中的图像 1,1
    • Remove the four screws that connect the chuck to the drill.
  4. Black and Decker LDX 120C Gear  Replacement: 步骤 4 中的图像 1,1
    • Remove the five screws on the front side of the drill.
  5. Black and Decker LDX 120C Gear  Replacement: 步骤 5 中的图像 1,1
    • Gently grab both sides of the drill casing, and separate both sides from each other.
  6. Black and Decker LDX 120C Gear  Replacement: 步骤 6 中的图像 1,1
    • At this point you should be able to separate both as illustrated.
  7. Black and Decker LDX 120C Gear  Replacement: 步骤 7 中的图像 1,1
    • Now all the components of the drill are visible and can be accessed.
  8. Black and Decker LDX 120C Gear  Replacement, Gear: 步骤 8 中的图像 1,1
    • After following the prerequisite guide you will be able to access the interior components of the drill.
  9. Black and Decker LDX 120C Gear  Replacement: 步骤 9 中的图像 1,1
    • Gently remove the top part (motor and chuck) from the rest of the drill.
  10. Black and Decker LDX 120C Gear  Replacement: 步骤 10 中的图像 1,1
    • Make sure you do that with care so that the connection doesn't get damaged.
  11. Black and Decker LDX 120C Gear  Replacement: 步骤 11 中的图像 1,1
    • To be able to get into the gears you will need to separate the motor from the rest.
    • And then you will be able to access the gears which is located between the motor and the chuck.
  12. Black and Decker LDX 120C Gear  Replacement: 步骤 12 中的图像 1,1
    • Twist the gauge to change between the gear.
    • If you don't hear a clicking sound then check the gears.
  13. Black and Decker LDX 120C Gear  Replacement: 步骤 13 中的图像 1,1
    • Twist the gear and see if the three gears rotate without jamming.
  14. Black and Decker LDX 120C Gear  Replacement: 步骤 14 中的图像 1,1
    • Check if any gear is chipped or broken in any way.
    • If it is then you will need to change the broken gear.
  15. Black and Decker LDX 120C Gear  Replacement: 步骤 15 中的图像 1,1
    • Using the spudger place it under the gear as illustrated.
  16. Black and Decker LDX 120C Gear  Replacement: 步骤 16 中的图像 1,1
    • The gear will remove with just a little amount of force.
  17. Black and Decker LDX 120C Gear  Replacement: 步骤 17 中的图像 1,1
    • The gear has been removed and now can be replaced by another gear.
结论
jeffrey zakka
于02/09/16注册
735 声望
创作了6篇指南
团队
USF Tampa, Team 11-5, Cheng Spring 2016 USF Tampa, Team 11-5, Cheng Spring 2016 的会员
USFT-CHENG-S16S11G5
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 32
总计 1,976
