跳转到主内容
Black and Decker JS660 Trigger Replacement
你所需要的
  1. Black and Decker JS660 Trigger Replacement, Housing Disassembly: 步骤 1 中的图像 1,2 Black and Decker JS660 Trigger Replacement, Housing Disassembly: 步骤 1 中的图像 2,2
    • Remove the nine torx 15.875mm screws on the front of the jigsaw using a T-15 torx screwdriver.
  2. Black and Decker JS660 Trigger Replacement: 步骤 2 中的图像 1,1
    • By separating the two housing halves, carefully remove the top plate.
  3. Black and Decker JS660 Trigger Replacement, Power Cord: 步骤 3 中的图像 1,1
    • Remove the two 12.7mm phillips head screws holding the power cord in place with a PH2 Phillips head screwdriver.
  4. Black and Decker JS660 Trigger Replacement: 步骤 4 中的图像 1,1
    • Remove the two 6.35mm flat head screws on the trigger with a 2.5 flat head screwdriver to disconnect the white and black cords.
  5. Black and Decker JS660 Trigger Replacement: 步骤 5 中的图像 1,1
    • Gently remove the black and white cord from the trigger assembly.
  6. Black and Decker JS660 Trigger Replacement, Trigger: 步骤 6 中的图像 1,1
    在这个步骤中使用的工具:
    • Use tweezers to press down on these tabs on the trigger assembly.
    • While the tab is depressed, the cord can be pulled out of the housing by using a moderate amount of force.
    • Each cord needs to be done separately.
  7. Black and Decker JS660 Trigger Replacement: 步骤 7 中的图像 1,1
    • Remove pink wires from trigger assembly.
结论
matt murray
于01/27/17注册
682 声望
创作了6篇指南
团队
Cal Poly, Team 22-9, Maness Winter 2017 Cal Poly, Team 22-9, Maness Winter 2017 的会员
CPSU-MANESS-W17S22G9
4 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 1,616
