跳转到主内容
Black and Decker JS660 Angle Lock Replacement
你所需要的
  1. Black and Decker JS660 Angle Lock Replacement, Base: 步骤 1 中的图像 1,2 Black and Decker JS660 Angle Lock Replacement, Base: 步骤 1 中的图像 2,2
    • Unscrew the eight screws to open up the jigsaw.
  2. Black and Decker JS660 Angle Lock Replacement: 步骤 2 中的图像 1,1
    • Use a screwdriver to remove the first screws securing the base to the jigsaw.
    • Remove the second screw.
    • Remove the base of the jigsaw.
  3. Black and Decker JS660 Angle Lock Replacement: 步骤 3 中的图像 1,2 Black and Decker JS660 Angle Lock Replacement: 步骤 3 中的图像 2,2
    • With the old jigsaw base off, replace it with the new base by following the steps in the reverse order.
    • Assemble the base on a steady surface.
  4. Black and Decker JS660 Angle Lock Replacement, Angle Lock: 步骤 4 中的图像 1,3 Black and Decker JS660 Angle Lock Replacement, Angle Lock: 步骤 4 中的图像 2,3 Black and Decker JS660 Angle Lock Replacement, Angle Lock: 步骤 4 中的图像 3,3
    • Remove the screw marked and the lever will slide out easily
    • The black screw must next be removed.
    • After removing the screw the lever will slide out of the jigsaw.
结论
Andrew Khouri
于02/08/16注册
468 声望
创作了4篇指南
团队
USF Tampa, Team 6-2, Eyestone Spring 2016 USF Tampa, Team 6-2, Eyestone Spring 2016 的会员
USFT-EYESTONE-S16S6G2
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 191
