跳转到主内容
Black and Decker IR02V-T Power Cord Replacement
你所需要的
  1. Black and Decker IR02V-T Power Cord Replacement, Power Cord: 步骤 1 中的图像 1,3 Black and Decker IR02V-T Power Cord Replacement, Power Cord: 步骤 1 中的图像 2,3 Black and Decker IR02V-T Power Cord Replacement, Power Cord: 步骤 1 中的图像 3,3
    • Remove the two silicone covers which encase the screws.
    • Remove both 1 mm screws using a T5 Torx screwdriver.
    • Pry open the plastic cover starting from the top of the iron.
  2. Black and Decker IR02V-T Power Cord Replacement: 步骤 2 中的图像 1,3 Black and Decker IR02V-T Power Cord Replacement: 步骤 2 中的图像 2,3 Black and Decker IR02V-T Power Cord Replacement: 步骤 2 中的图像 3,3
    • Remove both caps from the end of the wire by using pliers.
    • Unfold the metal in the caps using the pliers to release the exposed wire.
    • Remove the two 1 mm screws holding down the wire using a Phillips #00 screwdriver.
    • Once the wires are exposed separate and fold to opposite sides.
  3. Black and Decker IR02V-T Power Cord Replacement: 步骤 3 中的图像 1,3 Black and Decker IR02V-T Power Cord Replacement: 步骤 3 中的图像 2,3 Black and Decker IR02V-T Power Cord Replacement: 步骤 3 中的图像 3,3
    • Remove the old power cord from the iron completely.
    • Insert the new cord through the plastic cover and hole of the iron as demonstrated in the image.
  4. Black and Decker IR02V-T Power Cord Replacement: 步骤 4 中的图像 1,3 Black and Decker IR02V-T Power Cord Replacement: 步骤 4 中的图像 2,3 Black and Decker IR02V-T Power Cord Replacement: 步骤 4 中的图像 3,3
    • Expose about half an inch of wire by removing the silicone that encases it.
    • Tie the new wire into a knot and connect the wires accordingly.
    • Place the caps over the exposed wire and use pliers to tighten the metal to secure the wire.
  5. Black and Decker IR02V-T Power Cord Replacement: 步骤 5 中的图像 1,3 Black and Decker IR02V-T Power Cord Replacement: 步骤 5 中的图像 2,3 Black and Decker IR02V-T Power Cord Replacement: 步骤 5 中的图像 3,3
    • Once the caps are over the wires add the two 1 mm Phillips screws along with the small base plate which secures the wire.
    • When all wires are secure place the plastic cover and screw back in the 1mm Torx screws.
终点
Kevin B
于11/10/22注册
146 声望
撰写一个指南
团队
CSU Los Angeles, Team 2-28, Briggs Fall 2022 CSU Los Angeles, Team 2-28, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S2G28
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 56
总计 898
