跳转到主内容
Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal Replacement
你所需要的
  1. Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement, Vacuum Rubber Seal: 步骤 1 中的图像 1,1
    • Press the grey buttons with the unlock symbols on both sides of the nozzle.
    • Pull the nozzle upwards.
    • The other button cannot be seen on the image.
  2. Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: 步骤 2 中的图像 1,3 Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: 步骤 2 中的图像 2,3 Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: 步骤 2 中的图像 3,3
    • Use a plastic opening tool to pry the clear rubber seal away from the white plastic nozzle.
  3. Black and Decker Dustbuster CHV1510 Vacuum Rubber Seal  Replacement: 步骤 3 中的图像 1,1
    • Remove the clear seal from the nozzle.
    • If the nozzle does not connect to vacuum barrel while reassembling, readjust the rubber seal and try to attach the nozzle until the two snap into place.
结论
To reassemble your device, follow these instructions in reverse order. While reassembling, if the nozzle does not connect to vacuum barrel, readjust the rubber seal and try to attach the nozzle until the two snap into place.
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 12
过去 30 天: 19
总计 373
