跳转到主内容
Black and Decker Dustbuster CHV1510 Battery Pack Replacement
你所需要的
  1. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: 步骤 1 中的图像 1,2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: 步骤 1 中的图像 2,2
    • Remove the six exterior 2 mm Phillips #0 screws securing the 2 halves of the white shell together.
  2. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: 步骤 2 中的图像 1,2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: 步骤 2 中的图像 2,2
    • Remove nozzle by pressing two blue buttons on the side of the nozzle
  3. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: 步骤 3 中的图像 1,2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: 步骤 3 中的图像 2,2
    • Remove the dustbin by pressing the blue button on the vacuum's handle and lift the bin from the vacuum.
  4. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: 步骤 4 中的图像 1,3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: 步骤 4 中的图像 2,3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: 步骤 4 中的图像 3,3
    • Gently separate the two halves by pulling them apart, revealing the 14 cell battery pack behind the motor.
  5. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: 步骤 5 中的图像 1,2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: 步骤 5 中的图像 2,2
    • Removal of the battery pack is a tool-less process, lift the battery pack out of the vacuum gently, notice there are two wires connected to the battery.
  6. Black and Decker Dustbuster CHV1510 Battery Pack Replacement: 步骤 6 中的图像 1,2 Black and Decker Dustbuster CHV1510 Battery Pack Replacement: 步骤 6 中的图像 2,2
    • Disconnect the red wire from the battery pack (pull do not twist!) and do the same with the black wire
  7. Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: 步骤 7 中的图像 1,3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: 步骤 7 中的图像 2,3 Black and Decker Dustbuster CHV1510 Battery Pack Replacement, Battery Pack: 步骤 7 中的图像 3,3
    • Holding the battery pack firmly, disconnect the red and black wires from the battery pack by pulling them gently.
结论
2等其他人完成本指南。
Miguel Vilao
于11/09/17注册
376 声望
创作了3篇指南
团队
IUPUI, Team S7-G6, Baechle Fall 2017 IUPUI, Team S7-G6, Baechle Fall 2017 的会员
IUPUI-BAECHLE-F17S7G6
3 名成员
创作了3篇指南
一条评论
The battery pack in no longer available and the 14 cells would cost more than a brand new dustbuster (Feb 25, 2021). I managed to get almost 10-years out of my CHV1510.
glenn.watkins - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 32
总计 4,117
