跳转到主内容
Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement
你所需要的
  1. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement, Suction Rubber Seal: 步骤 1 中的图像 1,1
    • Press to blue unlock buttons at the base of the nozzle in word and pull forward .
  2. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: 步骤 2 中的图像 1,1
    • Locate rubber suction seal.
  3. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: 步骤 3 中的图像 1,1
    • Insert a metal spudger in between white plastic and rubber seal and gently drag spudger around see you lifting gently much like opening a can.
  4. Black and Decker DustBuster 15.6V Suction Rubber Seal Replacement: 步骤 4 中的图像 1,1
    • Align slits on the bottom of new suction seal then press into those slits.
    • The seal should not come above white plastic.
    • If the nozzle does not connect to vacuum barrel, readjust seal and try to attach nozzle until it snaps into place.
结论
Roberto Perez
于03/31/17注册
101 声望
撰写一个指南
团队
一条评论
Where can I buy a new suction seal.
Alison Junk - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 38
总计 2,330
