跳转到主内容
Black and Decker CM0700BZ Water Tank Replacement
你所需要的
  1. Black and Decker CM0700BZ Water Tank Replacement, Lid: 步骤 1 中的图像 1,2 Black and Decker CM0700BZ Water Tank Replacement, Lid: 步骤 1 中的图像 2,2
    • Open the lid of the coffee maker.
    • Remove the brew cup.
  2. Black and Decker CM0700BZ Water Tank Replacement: 步骤 2 中的图像 1,3 Black and Decker CM0700BZ Water Tank Replacement: 步骤 2 中的图像 2,3 Black and Decker CM0700BZ Water Tank Replacement: 步骤 2 中的图像 3,3
    • Place your finger, screwdriver, or spudger behind the corner of the tab.
    • Pull up on the tab until it disconnects from the coffee maker.
  3. Black and Decker CM0700BZ Water Tank Replacement: 步骤 3 中的图像 1,3 Black and Decker CM0700BZ Water Tank Replacement: 步骤 3 中的图像 2,3 Black and Decker CM0700BZ Water Tank Replacement: 步骤 3 中的图像 3,3
    • Hold the tab while pushing back on the lid.
    • The lid should open fully with the top of the lid facing down.
  4. Black and Decker CM0700BZ Water Tank Replacement: 步骤 4 中的图像 1,2 Black and Decker CM0700BZ Water Tank Replacement: 步骤 4 中的图像 2,2
    • Insert the flathead screwdriver or spudger into one of the inserts holding the lid.
    • Pry facing away from the lid to force the peg out.
    • You should hear a pop when it disconnects.
    • Hold the lid and pull it away from the other insert.
  5. Black and Decker CM0700BZ Water Tank Replacement: 步骤 5 中的图像 1,1
    • To also remove the shower head, use the Shower Head guide.
  6. Black and Decker CM0700BZ Water Tank Replacement, Water Tank: 步骤 6 中的图像 1,2 Black and Decker CM0700BZ Water Tank Replacement, Water Tank: 步骤 6 中的图像 2,2
    • Remove the carafe holder from the bottom of the coffee machine.
  7. Black and Decker CM0700BZ Water Tank Replacement: 步骤 7 中的图像 1,3 Black and Decker CM0700BZ Water Tank Replacement: 步骤 7 中的图像 2,3 Black and Decker CM0700BZ Water Tank Replacement: 步骤 7 中的图像 3,3
    • Place coffee maker on its side, with the bottom facing you.
    • Remove two 10mm Phillips #1 screws and one 10mm Tri-Point Y1 screws with their designated tips.
  8. Black and Decker CM0700BZ Water Tank Replacement: 步骤 8 中的图像 1,3 Black and Decker CM0700BZ Water Tank Replacement: 步骤 8 中的图像 2,3 Black and Decker CM0700BZ Water Tank Replacement: 步骤 8 中的图像 3,3
    • Slowly pry the bottom lid from the front.
    • You should hear a pop.
    • Pull up and remove the bottom lid.
  9. Black and Decker CM0700BZ Water Tank Replacement: 步骤 9 中的图像 1,1
  10. Black and Decker CM0700BZ Water Tank Replacement: 步骤 10 中的图像 1,3 Black and Decker CM0700BZ Water Tank Replacement: 步骤 10 中的图像 2,3 Black and Decker CM0700BZ Water Tank Replacement: 步骤 10 中的图像 3,3
    • Remove the four 10 mm Phillips #1 screws.
    • Slowly pull the water tank up to expose the water pipes
  11. Black and Decker CM0700BZ Water Tank Replacement: 步骤 11 中的图像 1,2 Black and Decker CM0700BZ Water Tank Replacement: 步骤 11 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Squeeze on the prongs with tweezers and hold.
    • Pull the water tank while squeezing the tighteners to loosen the water pipes off of the water tank.
结论
Shawn Robichaud
于10/26/22注册
729 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-2, Shaddix Spring 2023 UMass Dartmouth, Team 1-2, Shaddix Spring 2023 的会员
UMASSD-SHADDIX-S23S1G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 7
过去 30 天: 18
总计 246
