跳转到主内容
Black and Decker CM0700BZ Lid Replacement
你所需要的
  1. Black and Decker CM0700BZ Lid Replacement, Lid: 步骤 1 中的图像 1,2 Black and Decker CM0700BZ Lid Replacement, Lid: 步骤 1 中的图像 2,2
    • Open the lid of the coffee maker.
    • Remove the brew cup.
  2. Black and Decker CM0700BZ Lid Replacement: 步骤 2 中的图像 1,3 Black and Decker CM0700BZ Lid Replacement: 步骤 2 中的图像 2,3 Black and Decker CM0700BZ Lid Replacement: 步骤 2 中的图像 3,3
    • Place your finger, screwdriver, or spudger behind the corner of the tab.
    • Pull up on the tab until it disconnects from the coffee maker.
  3. Black and Decker CM0700BZ Lid Replacement: 步骤 3 中的图像 1,3 Black and Decker CM0700BZ Lid Replacement: 步骤 3 中的图像 2,3 Black and Decker CM0700BZ Lid Replacement: 步骤 3 中的图像 3,3
    • Hold the tab while pushing back on the lid.
    • The lid should open fully with the top of the lid facing down.
  4. Black and Decker CM0700BZ Lid Replacement: 步骤 4 中的图像 1,2 Black and Decker CM0700BZ Lid Replacement: 步骤 4 中的图像 2,2
    • Insert the flathead screwdriver or spudger into one of the inserts holding the lid.
    • Pry facing away from the lid to force the peg out.
    • You should hear a pop when it disconnects.
    • Hold the lid and pull it away from the other insert.
  5. Black and Decker CM0700BZ Lid Replacement: 步骤 5 中的图像 1,1
    • To also remove the shower head, use the Shower Head guide.
结论
Shawn Robichaud
于10/26/22注册
729 声望
创作了4篇指南
团队
UMass Dartmouth, Team 1-2, Shaddix Spring 2023 UMass Dartmouth, Team 1-2, Shaddix Spring 2023 的会员
UMASSD-SHADDIX-S23S1G2
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 25
总计 304
