跳转到主内容
Black and Decker CD2500 Motor Replacement
你所需要的
  1. Black and Decker CD2500 Motor Replacement, Motor (148331-03): 步骤 1 中的图像 1,1
    • Use a Phillips head screwdriver to unscrew 8 (3/4 in) Phillips screws from the housing set. Keep the screws all together.
    • Carefully remove the top housing
  2. Black and Decker CD2500 Motor Replacement: 步骤 2 中的图像 1,1
    • SHOCK WARNING: Ensure wire ends do NOT touch each other! Disconnect the battery from the drill by pulling out the 3 terminals.
    • Make sure the wires previously connected to the battery are moved away from the battery terminals.
    • Make sure the drill trigger assembly stays in place or a new guide will be necessary.
  3. Black and Decker CD2500 Motor Replacement: 步骤 3 中的图像 1,1
    • Grab the drill head with one hand and the gear with the other.
    • Pull away the second large gear from the motor gear and lift the drill head and gear up and out of the housing set.
  4. Black and Decker CD2500 Motor Replacement: 步骤 4 中的图像 1,1
    • Keep the drill head and gear assembly as one unit.
    • Make sure the gear assembly stays as one piece and the gold bearings do not fall off.
  5. Black and Decker CD2500 Motor Replacement: 步骤 5 中的图像 1,2 Black and Decker CD2500 Motor Replacement: 步骤 5 中的图像 2,2
    • Pull out the motor and lay it next to the drill; keep in mind that the white and red wires will still be attached to the motor.
  6. Black and Decker CD2500 Motor Replacement: 步骤 6 中的图像 1,1
    • The needle nose pliers will be used to detach the wires.
    • WARNING: Take extra care when using the pliers to detach the wires as both wires and motor terminals are delicate.
    • Use the pliers to “slide” the narrow sides of the motor terminals where the wires are attached. Pinching terminals will make it difficult to remove the wire from the terminal.
  7. Black and Decker CD2500 Motor Replacement: 步骤 7 中的图像 1,2 Black and Decker CD2500 Motor Replacement: 步骤 7 中的图像 2,2
    • Install new motor.
    • Attach wires to the new motor; make sure that the red wire is inserted back into the positive terminal on the new motor. The positive terminal is denoted by a (+) symbol.
    • The white wire will be inserted back into the negative terminal on the new motor. The negative terminal is denoted by the (-) symbol.
    • Make sure that the motor sits in the lower housing with the two terminals vertically in line, with the positive/red terminal on top.
    • The motor should fit snugly in the lower housing.
  8. Black and Decker CD2500 Motor Replacement: 步骤 8 中的图像 1,2 Black and Decker CD2500 Motor Replacement: 步骤 8 中的图像 2,2
    • Use the pliers to "slide" the wide sides of the motor terminals to firmly secure the wires back to the terminals.
  9. Black and Decker CD2500 Motor Replacement: 步骤 9 中的图像 1,3 Black and Decker CD2500 Motor Replacement: 步骤 9 中的图像 2,3 Black and Decker CD2500 Motor Replacement: 步骤 9 中的图像 3,3
    • Replace the gear and drill head assembly.
    • Put the drill head back into where it originally was secured. Make sure it lines up with the molding of the plastic housing. Move the second large gear into where it locks into the motor gear.
    • Make sure that the gold bearings and other small parts lock into the designated slots in the molding of the housing.
  10. Black and Decker CD2500 Motor Replacement: 步骤 10 中的图像 1,1
    • Reconnect the battery wires to the battery terminals by fitting the wire terminals over the battery terminals where they were originally fitted.
  11. Black and Decker CD2500 Motor Replacement: 步骤 11 中的图像 1,1
    • Put the upper housing back on the drill. make sure that the upper housing lines up with the lower housing screw holes.
    • Put all eight screws back in the slots.
    • Tighten the screws back into place with the Phillips head screwdriver.
    • After the screws are back in place, make sure they are all snug.
  12. Black and Decker CD2500 Motor Replacement: 步骤 12 中的图像 1,1
    • Turn on and test out the drill to make sure the new motor works.
    • Congratulations on successfully installing your new motor!
结论
Refer to this parts diagram if needed during these steps: http://www.ereplacementparts.com/images/...
Ashley
于09/24/13注册
182 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 3,517
