跳转到主内容
Black and Decker BV2500 Type 4 Switch Replacement
你所需要的
  1. Black and Decker BV2500 Type 4 Switch Replacement, Clamshell (Black Outer Casing): 步骤 1 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Switch Replacement: 步骤 2 中的图像 1,2 Black and Decker BV2500 Type 4 Switch Replacement: 步骤 2 中的图像 2,2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Switch Replacement, Switch: 步骤 3 中的图像 1,2 Black and Decker BV2500 Type 4 Switch Replacement, Switch: 步骤 3 中的图像 2,2
    • Locate and unscrew the ten 20 mm Phillips #2 screws in the orange casing with a Phillips #2 screwdriver.
    • Using your hands, lift off side of the orange casing with the screws facing you.
  4. Black and Decker BV2500 Type 4 Switch Replacement: 步骤 4 中的图像 1,3 Black and Decker BV2500 Type 4 Switch Replacement: 步骤 4 中的图像 2,3 Black and Decker BV2500 Type 4 Switch Replacement: 步骤 4 中的图像 3,3
    • Locate the switch on the handle of the blower.
    • Carefully remove the four wires that are attached to the switch.
    • Use your hand to push in the sides of the switch and slide out the wires.
  5. Black and Decker BV2500 Type 4 Switch Replacement: 步骤 5 中的图像 1,1
    • Note for reassembly: Be sure to put this back the way it was found.
结论
Jon Gori
于01/25/14注册
137 声望
撰写一个指南
团队
Cal Poly, Team 9-29, Maness Winter 2014 Cal Poly, Team 9-29, Maness Winter 2014 的会员
CPSU-MANESS-W14S9G29
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 26
总计 3,349
