跳转到主内容
Black and Decker BV2500 Type 4 Powerhead Assembly Replacement
你所需要的
  1. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement, Clamshell (Black Outer Casing): 步骤 1 中的图像 1,1
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement: 步骤 2 中的图像 1,2 Black and Decker BV2500 Type 4 Powerhead Assembly Replacement: 步骤 2 中的图像 2,2
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. Black and Decker BV2500 Type 4 Powerhead Assembly Replacement, Powerhead Assembly: 步骤 3 中的图像 1,1
    • The powerhead assembly is the entire orange part of the device.
    • Replace it with a new powerhead assembly.
结论
Angelica Chow
于01/25/14注册
409 声望
创作了3篇指南
团队
Cal Poly, Team 9-29, Maness Winter 2014 Cal Poly, Team 9-29, Maness Winter 2014 的会员
CPSU-MANESS-W14S9G29
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 1,182
