跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
This guide will take you through the process of replacing the power cord on the Black and Decker BV2500 Type 4. Without a power cord that works, the device will not turn on.
  1. Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
    • Using a Phillips #2 screwdriver, remove the six 20 mm screws in the black plastic casing (clamshell).
  2. Using your hands, remove the blower tube and clamshell. To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
    • Using your hands, remove the blower tube and clamshell.
    • To remove the clamshell, pull apart starting from the bottom until it is pulled out from the notches. Then slide it out away from the device.
  3. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  4. Using a Phillips #2 screwdriver, remove the ten 20 mm screws in the orange casing. Use your hands to lift off the side of the orange casing with the screws facing you.
    • Using a Phillips #2 screwdriver, remove the ten 20 mm screws in the orange casing.
    • Use your hands to lift off the side of the orange casing with the screws facing you.
  5. Locate the switch. Remove the 2 black and white wires with blue casings from the switch.
    • Locate the switch.
    • Remove the 2 black and white wires with blue casings from the switch.
    • Using your hands, push in the sides of the switch and slide out the wires.
  6. Remove the two 20 mm Phillips #2 screws that are holding in the power cord (located at the bottom of the leaf hog).
    • Remove the two 20 mm Phillips #2 screws that are holding in the power cord (located at the bottom of the leaf hog).
  7. Slide the power cord support off the power cord in the direction of the leads. Use your hands to pull the power cord out of the device with the lead end coming out last. Use your hands to pull the power cord out of the device with the lead end coming out last.
    • Slide the power cord support off the power cord in the direction of the leads.
    • Use your hands to pull the power cord out of the device with the lead end coming out last.
结论
Angelica Chow
于2014年01月25日注册
363 信誉积分
创作了3篇指南
团队
Cal Poly, Team 9-29, Maness Winter 2014 Cal Poly, Team 9-29, Maness Winter 2014 的会员
CPSU-MANESS-W14S9G29
4 名成员
创作了5篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 16
总计 1,848
