简介
You will need to have completed the prerequisite guides prior to this guide in order to execute it.
  1. Before disassembling the blender base, make sure the blender disconnected from any power outlet. Lift the jar straight up from the base without tilting the jar.
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver. This provides access to the base screws beneath.
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Remove the following screws that secure the top and  bottom halves of the base.
    • Remove the following screws that secure the top and bottom halves of the base.
      • One 1/4 Phillips screw
      • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  6. Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  7. Once you have the base removed, the circuit board should be clearly visible inside.
    • Once you have the base removed, the circuit board should be clearly visible inside.
  8. Remove the four screws located on the circuit board. Two are on the left side.
    • Remove the four screws located on the circuit board.
      • Two are on the left side.
      • Two are on the right side.
  9. Remove the following soldered connections with a soldering iron:
    • Remove the following soldered connections with a soldering iron:
      • Motor wires
      • Power cord wires
  10. Lift the circuit board straight up to remove it from the base.
    • Lift the circuit board straight up to remove it from the base.
  11. Once the circuit board has been freed from its screws it can be moved out of the way to gain access to the buttons.
    • Once the circuit board has been freed from its screws it can be moved out of the way to gain access to the buttons.
    • A single screw must be removed from the top as shown.
  12. Push firmly from the outside of the blender on the face of the buttons to pop it out of its locked position.
    • Push firmly from the outside of the blender on the face of the buttons to pop it out of its locked position.
  13. Provided is a front and a back view of a functioning button frame from the BL3000S. Check for cracks, bends, debris, or missing extentions and fastens.
    • Provided is a front and a back view of a functioning button frame from the BL3000S.
    • Check for cracks, bends, debris, or missing extentions and fastens.
结论
Austin Abernathy
于2012年10月05日注册
18 信誉积分
撰写一个指南
团队
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G34
4 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 7
总计 1,549
