跳转到主内容
Black and Decker BL3000S Motor Fan Replacement
你所需要的
  1. Black and Decker BL3000S Motor Fan Replacement, Blender Base: 步骤 1 中的图像 1,2 Black and Decker BL3000S Motor Fan Replacement, Blender Base: 步骤 1 中的图像 2,2
    • Before disassembling the blender base, make sure the blender disconnected from any power outlet.
    • Lift the jar straight up from the base without tilting the jar.
  2. Black and Decker BL3000S Motor Fan Replacement: 步骤 2 中的图像 1,1
    • Remove the top three 1/4 inch base screws using a Philip's head screwdriver.
  3. Black and Decker BL3000S Motor Fan Replacement: 步骤 3 中的图像 1,2 Black and Decker BL3000S Motor Fan Replacement: 步骤 3 中的图像 2,2
    • Remove the two base leg covers next to the power cord using pliers or a flat-head screwdriver.
    • This provides access to the base screws beneath.
  4. Black and Decker BL3000S Motor Fan Replacement: 步骤 4 中的图像 1,1
    • Remove the following screws that secure the top and bottom halves of the base.
    • One 1/4 Phillips screw
    • One TA-20 screw
    • Both screwdrivers must have a minimum of a three inch shank (length).
    • Screwdrivers with extenders will not fit down the access holes.
  5. Black and Decker BL3000S Motor Fan Replacement: 步骤 5 中的图像 1,1
    • Lift the top half of the base from the bottom half of the base to reveal the internal mechanism.
  6. Black and Decker BL3000S Motor Fan Replacement, Motor Fan: 步骤 6 中的图像 1,2 Black and Decker BL3000S Motor Fan Replacement, Motor Fan: 步骤 6 中的图像 2,2
    • Using pliers, remove the top nut from the fan and remove the washer.
    • Use a small towel to hold the fan in place. This makes taking off the nut easier to do.
  7. Black and Decker BL3000S Motor Fan Replacement: 步骤 7 中的图像 1,1
    • Lift the fan blades from the blender base.
结论
3等其他人完成本指南。
Andrew
于10/04/12注册
209 声望
创作了4篇指南
团队
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G34
4 名成员
创作了6篇指南
一条评论
mon mixeur a montre des itincelles et de la fumeé quel étape puis suivre pour le réparer
abdelkarim hassi - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 13
过去 30 天: 54
总计 4,441
