简介
This installation guide will help you separate the blades from the blender jar. Once separated, you can successfully install replacements blades or to check for any malfunctions with the blades.
  1. Make sure the blender is turned off and unplugged from all power.
    • Make sure the blender is turned off and unplugged from all power.
    • Remove the glass jar from the base of the blender.
  2. Remove the top lid from the blender jar.
    • Remove the top lid from the blender jar.
    • Twist the plastic base of the jar counterclockwise to remove it from the glass upper half.
    • Take care not to cut yourself on the blades.
    • Lift the rubber washer straight up to remove it from the blade assembly.
    • Lift the blades from the bottom cap.
结论
2等其他人完成本指南。
Andrew
于2012年10月04日注册
170 信誉积分
创作了4篇指南
团队
Cal Poly, Team 6-34, Regan Fall 2012 Cal Poly, Team 6-34, Regan Fall 2012 的会员
CPSU-REGAN-F12S6G34
4 名成员
创作了6篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 9
过去的30天: 32
总计 3,136
