跳转到主内容
Black and Decker BDERO100 Power Button Replacement
你所需要的
  1. Black and Decker BDERO100 Power Button Replacement, Chassis: 步骤 1 中的图像 1,2 Black and Decker BDERO100 Power Button Replacement, Chassis: 步骤 1 中的图像 2,2
    • Use the nylon spudger to remove the rubber ring from the filter attachment section.
    • The easiest way to do this is to place the spudger sideways and pulling out the ring.
  2. Black and Decker BDERO100 Power Button Replacement: 步骤 2 中的图像 1,2 Black and Decker BDERO100 Power Button Replacement: 步骤 2 中的图像 2,2
    • Use the TR20 Torx Security bit driver to unscrew the five 18.75mm Phillips screws from the warning label side of the chassis.
  3. Black and Decker BDERO100 Power Button Replacement: 步骤 3 中的图像 1,2 Black and Decker BDERO100 Power Button Replacement: 步骤 3 中的图像 2,2
    • Grab the plastic opening tool and place it on the separation line between both sides of the chassis.
    • Separate both sides and open the device.
    • Be careful not to lose or detach any internal parts while opening the sander.
  4. Black and Decker BDERO100 Power Button Replacement: 步骤 4 中的图像 1,2 Black and Decker BDERO100 Power Button Replacement: 步骤 4 中的图像 2,2
    • Hold the chassis and separate it from the device.
  5. Black and Decker BDERO100 Power Button Replacement, Power Button: 步骤 5 中的图像 1,2 Black and Decker BDERO100 Power Button Replacement, Power Button: 步骤 5 中的图像 2,2
    • Hold the power button and pull it out of the chassis.
  6. Black and Decker BDERO100 Power Button Replacement: 步骤 6 中的图像 1,2 Black and Decker BDERO100 Power Button Replacement: 步骤 6 中的图像 2,2
    • Select the cable that connects to the power button.
  7. Black and Decker BDERO100 Power Button Replacement: 步骤 7 中的图像 1,1
    • Expose the cable and lock system by peeling off the electric cover.
    • When attaching the new power cord you will need to make sure to cover this lock system with electrical tape.
  8. Black and Decker BDERO100 Power Button Replacement: 步骤 8 中的图像 1,2 Black and Decker BDERO100 Power Button Replacement: 步骤 8 中的图像 2,2
    • Push the security pin with the plastic spudger and simultaneously, pull gently on the cable to separate it from the button
  9. Black and Decker BDERO100 Power Button Replacement: 步骤 9 中的图像 1,2 Black and Decker BDERO100 Power Button Replacement: 步骤 9 中的图像 2,2
    • Detach the black wire connected to the power button from the motor. To do this, gently pull the cable while holding the power button.
结论
团队
USF Tampa, Team 1-5, Sullivan Spring 2016 USF Tampa, Team 1-5, Sullivan Spring 2016 的会员
USFT-SULLIVAN-S16S1G5
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 14
总计 1,055
