跳转到主内容
Black and Decker BDEDMT Power Cord Replacement
你所需要的
  1. Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: 步骤 1 中的图像 1,2 Black and Decker BDEDMT Power Cord Replacement, Detach Matrix Attachment: 步骤 1 中的图像 2,2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: 步骤 2 中的图像 1,3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: 步骤 2 中的图像 2,3 Black and Decker BDEDMT Power Cord Replacement, Remove Mounting Hardware: 步骤 2 中的图像 3,3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: 步骤 3 中的图像 1,2 Black and Decker BDEDMT Power Cord Replacement, Mounting Bracket: 步骤 3 中的图像 2,2
    • Using the T-handle screwdriver with the JIS 1 bit, unscrew the two lower black 12mm screws.
  4. Black and Decker BDEDMT Power Cord Replacement: 步骤 4 中的图像 1,2 Black and Decker BDEDMT Power Cord Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • There will be a white cord that runs from the power cord base to the circuit board located slightly above.
    • Use the tweezers to detach the entire white cord and blue connection piece as a whole from the circuit board.
  5. Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: 步骤 5 中的图像 1,2 Black and Decker BDEDMT Power Cord Replacement, Trigger Assembly: 步骤 5 中的图像 2,2
    • Physically pull up on the trigger device and remove it from the armature.
    • Flip trigger device over onto its back.
  6. Black and Decker BDEDMT Power Cord Replacement, Wire Removal: 步骤 6 中的图像 1,3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: 步骤 6 中的图像 2,3 Black and Decker BDEDMT Power Cord Replacement, Wire Removal: 步骤 6 中的图像 3,3
    • There is a screw labeled 3 located on the bottom left of the back of the trigger device.
    • Use a JIS 0 screwdriver to remove screw.
    • Gently tug on the black wire to pull the wire out of the device.
    • Now the power cord will be completely removed from the device.
结论
cayla dahl
于02/01/16注册
247 声望
创作了2篇指南
团队
UW Tacoma, Team 1-2, Rose Winter 2016 UW Tacoma, Team 1-2, Rose Winter 2016 的会员
UWT-ROSE-W16S1G2
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 50
总计 2,162
