跳转到主内容
Black and Decker BDEDMT Motor Replacement
你所需要的
  1. Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: 步骤 1 中的图像 1,2 Black and Decker BDEDMT Motor Replacement, Detach Matrix Attachment: 步骤 1 中的图像 2,2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: 步骤 2 中的图像 1,3 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: 步骤 2 中的图像 2,3 Black and Decker BDEDMT Motor Replacement, Remove Mounting Hardware: 步骤 2 中的图像 3,3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Motor Replacement, Motor: 步骤 3 中的图像 1,1
    • Gently pull up the motor and other components at the top of the device except the handle.
    • Watch out for the wires. They are connected to two compressed magnets in the black framework.
  4. Black and Decker BDEDMT Motor Replacement: 步骤 4 中的图像 1,2 Black and Decker BDEDMT Motor Replacement: 步骤 4 中的图像 2,2
    • Slide off the the black framework on the barring side.
    • You may have to compress the magnets in order to slide the framework off of the barring.
  5. Black and Decker BDEDMT Motor Replacement: 步骤 5 中的图像 1,2 Black and Decker BDEDMT Motor Replacement: 步骤 5 中的图像 2,2
    • Remove the release button attached at the front of the motor.
    • It may have already come off during Step 3.
  6. Black and Decker BDEDMT Motor Replacement: 步骤 6 中的图像 1,2 Black and Decker BDEDMT Motor Replacement: 步骤 6 中的图像 2,2
    • Work the silver magnetic ring off of the motor through the barring end.
    • The motor is now free.
结论
另外一个人完成了本指南。
Tyler Yurina
于02/01/16注册
419 声望
创作了2篇指南
团队
UW Tacoma, Team 1-2, Rose Winter 2016 UW Tacoma, Team 1-2, Rose Winter 2016 的会员
UWT-ROSE-W16S1G2
4 名成员
创作了11篇指南
3条评论
Hi,
Please can you tell me where to find the motor replacement part for this tool?
Thank you
Renato - 回复
I have this tool and the attachments and I absolutely love it…but I'm pretty sure the gears are stripped…do you know anything about replacing those?
cwilson0713@gmail.com - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 60
总计 2,603
