跳转到主内容
Black and Decker BDEDMT Directional Switch Replacement
你所需要的
  1. Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: 步骤 1 中的图像 1,2 Black and Decker BDEDMT Directional Switch Replacement, Detach Matrix Attachment: 步骤 1 中的图像 2,2
    • Remember to disconnect the device from all external power sources.
    • To detach the matrix attachment piece, press down on the attachment release button located at the top of the device.
    • Leaving your finger pressed down on the button, simply pull on the attachment to release it.
  2. Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: 步骤 2 中的图像 1,3 Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: 步骤 2 中的图像 2,3 Black and Decker BDEDMT Directional Switch Replacement, Remove Mounting Hardware: 步骤 2 中的图像 3,3
    • Using a JIS 1 screwdriver, unscrew seven 19mm outer screws located on the armature.
    • Using the same screwdriver, unscrew the 12mm outer screw located on the armature.
  3. Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: 步骤 3 中的图像 1,2 Black and Decker BDEDMT Directional Switch Replacement, Directional Switch: 步骤 3 中的图像 2,2
    • Gently pull up on the trigger module.
    • Be sure to not loosen or disturb any wiring.
  4. Black and Decker BDEDMT Directional Switch Replacement: 步骤 4 中的图像 1,2 Black and Decker BDEDMT Directional Switch Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • With the trigger module out of the way you will then remove the metal piece that is located behind the directional switch and has the spring attached to it.
    • Do this by simply pulling up on the metal with your fingers or your tweezers.
    • Make sure to not loosen or remove the black trigger stopper.
  5. Black and Decker BDEDMT Directional Switch Replacement: 步骤 5 中的图像 1,2 Black and Decker BDEDMT Directional Switch Replacement: 步骤 5 中的图像 2,2
    • The black directional switch can now be freely removed.
结论
Tyler Yurina
于02/01/16注册
419 声望
创作了2篇指南
团队
UW Tacoma, Team 1-2, Rose Winter 2016 UW Tacoma, Team 1-2, Rose Winter 2016 的会员
UWT-ROSE-W16S1G2
4 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 20
总计 400
