跳转到主内容
Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement
你所需要的
  1. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement, Line: 步骤 1 中的图像 1,1
    • To prepare a new line for your weed whacker, use your utility scissors and cut a piece of line between 30 cm and 50 cm long.
  2. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 步骤 2 中的图像 1,1
    • Press the buttons on the opposite sides of the trimmer cover and lift it off the head of the trimmer.
  3. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 步骤 3 中的图像 1,2 Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 步骤 3 中的图像 2,2
    • Remove the spool from the trimmer head.
    • Be careful when removing the spool as the line is still being fed through the access hole.
  4. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 步骤 4 中的图像 1,2 Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 步骤 4 中的图像 2,2
    • Remove any remaining pieces of old line by sliding it out of the space it sits in.
    • Insert the new line into the opening.
  5. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 步骤 5 中的图像 1,1
    • Wrap your line around the spool and make sure you leave 10 cm of the line loose.
    • There are arrows on the spool indicating which direction to wrap the line.
  6. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 步骤 6 中的图像 1,1
    • Insert the end of the line into the metal hole.
    • Feed about 10 cm of line through the hole.
  7. Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 步骤 7 中的图像 1,2 Black and Decker 12" Grass Hog Automatic Feed String Trimmer GH400 Line Replacement: 步骤 7 中的图像 2,2
    • Place spool back in place and snap it into place.
    • Place the cover back on the head of the weed whacker.
结论
另外一个人完成了本指南。
Camille Guzman
于09/19/22注册
145 声望
撰写一个指南
团队
York University, Team A-5, Morris Fall 2022 York University, Team A-5, Morris Fall 2022 的会员
YORK-MORRIS-F22SAG5
3 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 24
过去 30 天: 96
总计 1,655
