跳转到主内容
Bissell Zing 2156A Cord Retraction Mechanism Replacement
你所需要的
  1. Bissell Zing 2156A Cord Retraction Mechanism Replacement, Rear Wheel: 步骤 1 中的图像 1,1
    • Remove the dust tank, so the vacuum can lie upside down easily.
    • Press the grey button while pulling up.
  2. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 2 中的图像 1,1
    • Flip the vacuum upside down.
  3. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 3 中的图像 1,3 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 3 中的图像 2,3 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 3 中的图像 3,3
    • Place your hand inside between the wheel and vacuum and pry the wheel off.
    • Repeat with the other side.
  4. Bissell Zing 2156A Cord Retraction Mechanism Replacement, Case: 步骤 4 中的图像 1,2 Bissell Zing 2156A Cord Retraction Mechanism Replacement, Case: 步骤 4 中的图像 2,2
    • Remove the two 18.1 mm screws using a Phillips #0 screwdriver.
    • Remove the four 18.1 mm screws under the wheels using a Phillips #0 screwdriver.
    • Don't try this until you have removed the wheels!
  5. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 5 中的图像 1,3 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 5 中的图像 2,3 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 5 中的图像 3,3
    • Use the spudger to loosen the top case from the bottom. Make sure to loosen it all around the bottom and lift up.
  6. Bissell Zing 2156A Cord Retraction Mechanism Replacement, Cord Retraction Mechanism: 步骤 6 中的图像 1,2 Bissell Zing 2156A Cord Retraction Mechanism Replacement, Cord Retraction Mechanism: 步骤 6 中的图像 2,2
    • The spring only needs replacing if the arm is loose!
    • Remove the 20mm spring and replace it with a working spring.
    • Press down the spring, angle it away from the lever arm, and then pull out the spring.
  7. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 7 中的图像 1,2 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 7 中的图像 2,2
    • Pull on the body to let the mechanism's pin move.
    • Pull the mechanism out.
    • Be careful of the red and black wires, as they can get snagged on the casing!
  8. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 8 中的图像 1,2 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 8 中的图像 2,2
    • Tension the part by holding the stationary mechanism and rotating the wheel counterclockwise.
    • When the retraction mechanism is tensioned, it should be wound up, not flat.
    • Fully retract the cord before reinserting it, so you keep every bit of tension available.
  9. Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 9 中的图像 1,3 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 9 中的图像 2,3 Bissell Zing 2156A Cord Retraction Mechanism Replacement: 步骤 9 中的图像 3,3
    • This step is only needed if fully removing the cord retraction mechanism. If the cord doesn't need to come out, this cowling can stay untouched.
    • Use a spudger to pop the clips out of the cowling's outside face. Pull it out.
    • Remove the holders on the inside of the cowling so the bracket can be pivoted out.
    • Separate the cowling and bracket and remove the cord.
    • Keep track of the small bracket; if it's lost the part won't go in right.
结论
另外一个人完成了本指南。
Emma R
于02/14/24注册
498 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 44
总计 110
