跳转到主内容
Bissell Swivel Rewind Pet Vacuum Belt Replacement
你所需要的
  1. Bissell Swivel Rewind Pet Vacuum Belt Replacement, Belt: 步骤 1 中的图像 1,3 Bissell Swivel Rewind Pet Vacuum Belt Replacement, Belt: 步骤 1 中的图像 2,3 Bissell Swivel Rewind Pet Vacuum Belt Replacement, Belt: 步骤 1 中的图像 3,3
    • Using your Phillips #2 screwdriver, remove the six 17.5 mm screws on the front panel that holds the brush roll in place.
  2. Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 2 中的图像 1,3 Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 2 中的图像 2,3 Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 2 中的图像 3,3
    • Pull the front panel to remove it and access the brush roll and the broken belt.
  3. Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 3 中的图像 1,3 Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 3 中的图像 2,3 Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 3 中的图像 3,3
    • Remove the broken belt.
    • Hold the brush roll on both ends and pull it outward to remove it.
  4. Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 4 中的图像 1,2 Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 4 中的图像 2,2
    • Put the new belt on the metal that makes the belt turn. It is located close to the rear tire.
  5. Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 5 中的图像 1,2 Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 5 中的图像 2,2
    • Put the new belt on the brush roll where there is a black spot.
  6. Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 6 中的图像 1,2 Bissell Swivel Rewind Pet Vacuum Belt Replacement: 步骤 6 中的图像 2,2
    • Pull the brush roll upward and align it in its original spot.
    • This may take some force.
结论
3等其他人完成本指南。
团队
UW Tacoma, Team S1-G6, Cardinal Summer 2020 UW Tacoma, Team S1-G6, Cardinal Summer 2020 的会员
UWT-CARDINAL-SU20S1G6
1 名成员
创作了1篇指南
一条评论
Ty but where do I buy the belt??
hysell64@gmail.com - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 15
过去 30 天: 52
总计 3,457
