跳转到主内容
简介
This replacement guide will cover how to replace the brush motor on the Bissell SpotBot Pet carpet cleaner.
配件
没有特定配件。
  1. Set your Bissell SpotBot Pet on a flat surface to begin your repair.
    • Set your Bissell SpotBot Pet on a flat surface to begin your repair.
  2. Lift straight up on the right container to remove it from the vacuum.
    • Lift straight up on the right container to remove it from the vacuum.
  3. Lift up on the tab on the top of the vacuum and then lift straight up on the left container to remove it. Lift up on the tab on the top of the vacuum and then lift straight up on the left container to remove it.
    • Lift up on the tab on the top of the vacuum and then lift straight up on the left container to remove it.
  4. Remove the vacuum tube by sliding it out of its holder on the side.
    • Remove the vacuum tube by sliding it out of its holder on the side.
  5. Unscrew the 4 screws on the top of the device and gently lift the top half up. A ribbon cable is still attached to the underside of the top half.
    • Unscrew the 4 screws on the top of the device and gently lift the top half up.
    • A ribbon cable is still attached to the underside of the top half.
  6. Unplug the ribbon cable connecting the bottom half to the control panel on the top half.  Set the top off to the side. Unplug the ribbon cable connecting the bottom half to the control panel on the top half.  Set the top off to the side. Unplug the ribbon cable connecting the bottom half to the control panel on the top half.  Set the top off to the side.
    • Unplug the ribbon cable connecting the bottom half to the control panel on the top half. Set the top off to the side.
  7. Unscrew the screw next to the white plastic wiring harness box. This will allow you to set the box off to the side. Unscrew the screw next to the white plastic wiring harness box. This will allow you to set the box off to the side.
    • Unscrew the screw next to the white plastic wiring harness box. This will allow you to set the box off to the side.
  8. Unscrew the screws on the plastic holder on the right side of the device. Remove the plastic holder from the vacuum.
    • Unscrew the screws on the plastic holder on the right side of the device. Remove the plastic holder from the vacuum.
    • Unscrew the screws that mount the vacuum motor to the device
  9. Unplug the wires connecting the motor to the wiring harness. Unplug the wires connecting the motor to the wiring harness.
    • Unplug the wires connecting the motor to the wiring harness.
  10. Lift the white suction motor from the right side of the device. Lift it straight up and set it off to the side of the vacuum. Lift the white suction motor from the right side of the device. Lift it straight up and set it off to the side of the vacuum.
    • Lift the white suction motor from the right side of the device. Lift it straight up and set it off to the side of the vacuum.
  11. Remove the screws for the brush motor. This motor controls the automatic scrubbing mechanism. Remove the screws for the brush motor. This motor controls the automatic scrubbing mechanism.
    • Remove the screws for the brush motor. This motor controls the automatic scrubbing mechanism.
结论
5等其他人完成本指南。
Anthony Bonvino
于2017年09月26日注册
437 信誉积分
创作了2篇指南
团队
Cal Poly, Team S7-G3, Banghart Fall 2017 Cal Poly, Team S7-G3, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S7G3
4 名成员
创作了2篇指南
一条评论
hi i think you did an amazing job of breaking down how to disasemble this spotbot. i have the exact same one and though it works great suction is amazing, the brushes dont spin and i took it apart completely except i didnt know where the motor was that controlled the brushes until reading this. thanks so much
art - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 5
过去的30天: 21
总计 982
