跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
Bissell SpotBot Pet Repair Brush Motor Replacement
你所需要的
  1. Bissell SpotBot Pet Repair Brush Motor Replacement, Brush Motor: 步骤 1 中的图像 1,1
    • Set your Bissell SpotBot Pet on a flat surface to begin your repair.
  2. Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 2 中的图像 1,1
    • Lift straight up on the right container to remove it from the vacuum.
  3. Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 3 中的图像 1,2 Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 3 中的图像 2,2
    • Lift up on the tab on the top of the vacuum and then lift straight up on the left container to remove it.
  4. Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 4 中的图像 1,1
    • Remove the vacuum tube by sliding it out of its holder on the side.
  5. Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 5 中的图像 1,2 Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 5 中的图像 2,2
    • Unscrew the 4 screws on the top of the device and gently lift the top half up.
    • A ribbon cable is still attached to the underside of the top half.
  6. Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 6 中的图像 1,3 Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 6 中的图像 2,3 Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 6 中的图像 3,3
    • Unplug the ribbon cable connecting the bottom half to the control panel on the top half. Set the top off to the side.
  7. Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 7 中的图像 1,2 Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 7 中的图像 2,2
    • Unscrew the screw next to the white plastic wiring harness box. This will allow you to set the box off to the side.
  8. Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 8 中的图像 1,1
    • Unscrew the screws on the plastic holder on the right side of the device. Remove the plastic holder from the vacuum.
    • Unscrew the screws that mount the vacuum motor to the device
  9. Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 9 中的图像 1,2 Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 9 中的图像 2,2
    • Unplug the wires connecting the motor to the wiring harness.
  10. Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 10 中的图像 1,2 Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 10 中的图像 2,2
    • Lift the white suction motor from the right side of the device. Lift it straight up and set it off to the side of the vacuum.
  11. Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 11 中的图像 1,2 Bissell SpotBot Pet Repair Brush Motor Replacement: 步骤 11 中的图像 2,2
    • Remove the screws for the brush motor. This motor controls the automatic scrubbing mechanism.
结论
5等其他人完成本指南。
团队
Cal Poly, Team S7-G3, Banghart Fall 2017 Cal Poly, Team S7-G3, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S7G3
4 名成员
创作了4篇指南
一条评论
hi i think you did an amazing job of breaking down how to disasemble this spotbot. i have the exact same one and though it works great suction is amazing, the brushes dont spin and i took it apart completely except i didnt know where the motor was that controlled the brushes until reading this. thanks so much
art - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 34
总计 1,462
