跳转到主内容
Bissell SmartClean 1605 Roller Brush Replacement
你所需要的
  1. Bissell SmartClean 1605 Roller Brush Replacement, Roller Brush: 步骤 1 中的图像 1,1
    • Make sure your device is powered off.
  2. Bissell SmartClean 1605 Roller Brush Replacement: 步骤 2 中的图像 1,1
    • Gently flip device over.
  3. Bissell SmartClean 1605 Roller Brush Replacement: 步骤 3 中的图像 1,3 Bissell SmartClean 1605 Roller Brush Replacement: 步骤 3 中的图像 2,3 Bissell SmartClean 1605 Roller Brush Replacement: 步骤 3 中的图像 3,3
    • Remove plastic plate cover to reveal brush roller.
  4. Bissell SmartClean 1605 Roller Brush Replacement: 步骤 4 中的图像 1,2 Bissell SmartClean 1605 Roller Brush Replacement: 步骤 4 中的图像 2,2
    • Remove brush roller from its slots on either side.
    • Apply pressure to one side and pull the roller out of its opposite slot.
    • It's like taking out a spring loaded toilet paper holder.
结论
Austin Maranville
于09/26/17注册
117 声望
撰写一个指南
团队
Cal Poly, Team S7-G4, Banghart Fall 2017 Cal Poly, Team S7-G4, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S7G4
5 名成员
创作了5篇指南
13条评论
What if mine don't feel spring loaded and the brushe seems like it was just wants to fall out
Brian - 回复
I'm having the same issue. The spring is not reloading to the brush just falls out
Rachel -
Same issue with mine. Took it apart and found that the side with spring loaded holder was broken.
Ryan Beaudre - 回复
I am having the same issue it’s like a part is missing for the pin side not the square sides to hold the brush roll in place.
Geoffrey Fraser - 回复
I have the same issue…it seems that the spring part was lost.have anyone of you find a replacement parts?
Mazinger Z - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 1,031
