跳转到主内容
Bissell Powerglide Cordless Release Button Replacement
你所需要的
  1. Bissell Powerglide Cordless Release Button Replacement, Release Button: 步骤 1 中的图像 1,2 Bissell Powerglide Cordless Release Button Replacement, Release Button: 步骤 1 中的图像 2,2
    • Press the release button while pulling up on the head of the vacuum to remove the head.
  2. Bissell Powerglide Cordless Release Button Replacement: 步骤 2 中的图像 1,1
    • Using a Phillips head screwdriver, unscrew the four screws holding the panel to the shaft of the vacuum.
  3. Bissell Powerglide Cordless Release Button Replacement: 步骤 3 中的图像 1,2 Bissell Powerglide Cordless Release Button Replacement: 步骤 3 中的图像 2,2
    • Pry the panel up using a spudger and pull up firmly just enough to see the clips of wire on the sides.
  4. Bissell Powerglide Cordless Release Button Replacement: 步骤 4 中的图像 1,1
    • Remove the wire clips on both sides of the shaft.
  5. Bissell Powerglide Cordless Release Button Replacement: 步骤 5 中的图像 1,1
    • Pull the top piece out of the shaft.
  6. Bissell Powerglide Cordless Release Button Replacement: 步骤 6 中的图像 1,3 Bissell Powerglide Cordless Release Button Replacement: 步骤 6 中的图像 2,3 Bissell Powerglide Cordless Release Button Replacement: 步骤 6 中的图像 3,3
    • Pinch the two pairs of plastic catches (circled in the picture) to release the button.
结论
Khanh Fleshman
于01/28/18注册
133 声望
撰写一个指南
团队
CPSU-BANGHART-W18S21G2 CPSU-BANGHART-W18S21G2 的会员
Community
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 149
