跳转到主内容
Bissell Powerglide Cordless Debris Canister Funnel Replacement
你所需要的
  1. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: 步骤 1 中的图像 1,3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: 步骤 1 中的图像 2,3 Bissell Powerglide Cordless Debris Canister Funnel Replacement, Filter: 步骤 1 中的图像 3,3
    • Remove the gray motor unit by twisting it so that the black triangle moves from the "locked" to the "unlocked" position.
  2. Bissell Powerglide Cordless Debris Canister Funnel Replacement: 步骤 2 中的图像 1,1
    • Remove the filter from the dirt canister.
  3. Bissell Powerglide Cordless Debris Canister Funnel Replacement, Debris Canister Funnel: 步骤 3 中的图像 1,1
    • Separate the cyclone assembly from the dirt tank by twisting the pieces counterclockwise.
  4. Bissell Powerglide Cordless Debris Canister Funnel Replacement: 步骤 4 中的图像 1,1
    • Use a Phillips head screwdriver to remove the three screws from the bottom of the cyclone assembly.
    • Remove the bottom of the assembly.
  5. Bissell Powerglide Cordless Debris Canister Funnel Replacement: 步骤 5 中的图像 1,2 Bissell Powerglide Cordless Debris Canister Funnel Replacement: 步骤 5 中的图像 2,2
    • Twist the clear plastic capsule with the fins counterclockwise to remove it.
  6. Bissell Powerglide Cordless Debris Canister Funnel Replacement: 步骤 6 中的图像 1,1
    • Twist the blue parts counterclockwise with a good amount of force to remove them.
结论
Joseph Adam Johnson
于02/05/18注册
511 声望
创作了5篇指南
团队
Cal Poly, Team S21-G2, Banghart Winter 2018 Cal Poly, Team S21-G2, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S21G2
5 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 218
