跳转到主内容
Bissell OptiClean Cyclonic Vacuum Filter Replacements
你所需要的
  1. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: 步骤 1 中的图像 1,2 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Flex Hose with Handle: 步骤 1 中的图像 2,2
    • Grab hold of both the flex hose handle and the extension wand.
    • Pull straight out to detach the handle from the extension wand.
  2. Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 2 中的图像 1,1
    • Locate the lock clip on the other end of the flex hose.
  3. Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 3 中的图像 1,2 Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 3 中的图像 2,2
    • Hold down the lock clip to unlock the flex hose from the vacuum.
    • Remove the flex hose from the vacuum.
  4. Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: 步骤 4 中的图像 1,3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: 步骤 4 中的图像 2,3 Bissell OptiClean Cyclonic Vacuum Filter Replacements, Filters: 步骤 4 中的图像 3,3
    • After removing hose, place vacuum on back and unclip the top compartment.
    • Open the compartment.
    • Pull the dirt collection box out of the vacuum.
  5. Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 5 中的图像 1,3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 5 中的图像 2,3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 5 中的图像 3,3
    • Place dirt collection box to the side.
    • Locate the Pre-Motor Filter.
    • Pull the filter out by grabbing the pull tab on top.
  6. Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 6 中的图像 1,3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 6 中的图像 2,3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 6 中的图像 3,3
    • Turn vacuum around and locate the filter cover on the bottom.
    • Place fingers in the opening and pull off the filter cover.
    • Place fingers on each tab on the Post-Motor HEPA Media Filter and pull out.
  7. Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 7 中的图像 1,3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 7 中的图像 2,3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 7 中的图像 3,3
    • Take filter out to clean or replace.
    • To clean Dirt Collection Box, unlatch lid and take off.
  8. Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 8 中的图像 1,3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 8 中的图像 2,3 Bissell OptiClean Cyclonic Vacuum Filter Replacements: 步骤 8 中的图像 3,3
    • Flip Dirt Collection Box over and locate the push tab.
    • Push the Dirt Cup HEPA Media Filter up to take it off.
    • Picture 3 Shows all the filters taken out of the vacuum.
结论
团队
Cal Poly, Team S12-G1, Banghart Winter 2018 Cal Poly, Team S12-G1, Banghart Winter 2018 的会员
CPSU-BANGHART-W18S12G1
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 731
