跳转到主内容
Bionaire Mini Tower Fan Blade Replacement
你所需要的
  1. Bionaire Mini Tower Fan Blade Replacement, Blades: 步骤 1 中的图像 1,2 Bionaire Mini Tower Fan Blade Replacement, Blades: 步骤 1 中的图像 2,2
    • There are 6 screws holding the entire fan together, which need to be removed to access the internals of the fan.
  2. Bionaire Mini Tower Fan Blade Replacement: 步骤 2 中的图像 1,1
    • Once the screws are all off, the fan can be pulled apart with a little bit of force. However, not too much force is required.
  3. Bionaire Mini Tower Fan Blade Replacement: 步骤 3 中的图像 1,3 Bionaire Mini Tower Fan Blade Replacement: 步骤 3 中的图像 2,3 Bionaire Mini Tower Fan Blade Replacement: 步骤 3 中的图像 3,3
    • Once you have the fan apart, in order to get more maneuverability, the wire attached to the motor needs to be loosened. This can be done by removing the two screws highlighted in red.
  4. Bionaire Mini Tower Fan Blade Replacement: 步骤 4 中的图像 1,2 Bionaire Mini Tower Fan Blade Replacement: 步骤 4 中的图像 2,2
    • To get more maneuverability, remove the button panel. This can be done by removing the 2 screws on either side of the panel in order to fully remove it.
  5. Bionaire Mini Tower Fan Blade Replacement: 步骤 5 中的图像 1,2 Bionaire Mini Tower Fan Blade Replacement: 步骤 5 中的图像 2,2
    • Carefully remove the panel by pulling on it. It should fall out easily and separate completely from its housing.
  6. Bionaire Mini Tower Fan Blade Replacement: 步骤 6 中的图像 1,2 Bionaire Mini Tower Fan Blade Replacement: 步骤 6 中的图像 2,2
    • The bolt that you need to remove is inside of the pre-installed fan blades. With your pliers, grab a hold of the nut and twist to the RIGHT. This will allow you to remove the fan blades.
  7. Bionaire Mini Tower Fan Blade Replacement: 步骤 7 中的图像 1,3 Bionaire Mini Tower Fan Blade Replacement: 步骤 7 中的图像 2,3 Bionaire Mini Tower Fan Blade Replacement: 步骤 7 中的图像 3,3
    • In order to install the new blades, there are two pieces that you have to match up. The blades and pole both have a flat side that you have to match up in order for the blades to stay on.
    • Make sure when you install the blades, it blows air when it rotates in a counterclockwise fashion.
  8. Bionaire Mini Tower Fan Blade Replacement: 步骤 8 中的图像 1,1
    • Tighten the bolt to the left and you have successfully installed your new fan blades.
结论
3等其他人完成本指南。
Kyle Taggard
于09/29/15注册
218 声望
撰写一个指南
团队
Cal Poly, Team 14-4, Green Fall 2015 Cal Poly, Team 14-4, Green Fall 2015 的会员
CPSU-GREEN-F15S14G4
5 名成员
创作了16篇指南
一条评论
Thank you the instructions were spot on
Jason Mendez - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 38
总计 3,664
