跳转到主内容
Bionaire BAP 600 Air Filter Replacement
  1. Bionaire BAP 600 Air Filter Replacement, Base/Intake: 步骤 1 中的图像 1,1
    • Rotate base counterclockwise, supporting top with opposite hand.
  2. Bionaire BAP 600 Air Filter Replacement: 步骤 2 中的图像 1,1
    • Pull base away from housing exposing air filter.
  3. Bionaire BAP 600 Air Filter Replacement, Air Filter: 步骤 3 中的图像 1,1
    • Grab the edge of the filter housing and pull the filter away from the rest of the device.
  4. Bionaire BAP 600 Air Filter Replacement: 步骤 4 中的图像 1,1
    • Gently pull apart each fold of the filter to check for abrasions or other anomalies. Clean with a dust rag if necessary.
结论
另外一个人完成了本指南。
Nick Miller
于10/26/16注册
167 声望
创作了3篇指南
团队
IUPUI, Team 4-4, Baechle Fall 2016 IUPUI, Team 4-4, Baechle Fall 2016 的会员
IUPUI-BAECHLE-F16S4G4
5 名成员
创作了7篇指南
3条评论
Bonjour.merci pour le tutoriel,mais où trouver un filtre…
Frederic Battele - 回复
Where such a filter can be bought? I was in Italy when I order mine from Amazon (UK) but can't find the filter to replace, I damaged mine.
Any idea?
Nuno Filipe - 回复
I been searching for 3 years now. They don't make them. You have to buy a new one. I went to Honeywell and not had a problem.
Blake PS -
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 23
总计 2,501
