跳转到主内容
Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement
你所需要的
  1. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Spark Plug Disconnection: 步骤 1 中的图像 1,2 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Spark Plug Disconnection: 步骤 1 中的图像 2,2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: 步骤 2 中的图像 1,3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: 步骤 2 中的图像 2,3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement, Blade: 步骤 2 中的图像 3,3
    • Lift to raise the front end of the brush cutter.
    • Place a jack stand or other secure support under the deck to prevent the brush cutter from tipping forward.
  3. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 3 中的图像 1,3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 3 中的图像 2,3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 3 中的图像 3,3
    • Use a 13/16" socket to remove the bolt securing the blade.
    • If needed, wedge a wood block between the blade and the deck to prevent the blade from turning.
    • During reassembly, make sure the blade is fully seated on the spindle, and use a torque wrench to tighten the bolt to 33-38 ft lbs.
  4. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 4 中的图像 1,3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 4 中的图像 2,3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 4 中的图像 3,3
    • Wear gloves or be careful when handling the blade.
    • Remove the bolt and friction washer, and remove the blade.
    • Use a new bolt and washer when replacing the blade.
    • If the large cylindrical blade adapter falls off the spindle, check to make sure the key is correctly positioned inside the adapter, and then align the key with the notch on the spindle when installing it.
  5. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 5 中的图像 1,3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 5 中的图像 2,3 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 5 中的图像 3,3
    • Use a 3/8" socket or wrench to remove the four 21 mm bolts securing the top cover to the deck.
  6. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 6 中的图像 1,2 Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 6 中的图像 2,2
    • Lift and remove the top cover.
  7. Billy Goat Brush Cutter BC2600HHF 2015 Blade Replacement: 步骤 7 中的图像 1,1
    • Using a 9/16” socket or wrench, make sure the bolt at the top of the spindle is tight.
结论
2等其他人完成本指南。
Jeff Suovanen
于08/06/13注册
427,802 声望
创作了259篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,731篇指南
一条评论
how about a part number for the replacement blade that you show how to change,
ALLAN - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 31
总计 2,250
