跳转到主内容
加入维修社区 - 创建账户
Bike Chain Replacement
你所需要的
  1. Bike Chain Replacement, Pick up the slipped chain and position: 步骤 1 中的图像 1,1
    • Pick up the slipped chain and position it to the top of the correct gear while pedaling.
  2. Bike Chain Replacement, Release the derailleur and push the pedal forward: 步骤 2 中的图像 1,1
    • Once the chain teeth are locked in place, slowly release the derailleur and push the pedal forward to move the back wheel.
  3. Bike Chain Replacement, Continue pedaling: 步骤 3 中的图像 1,1
    • Continue pedaling until the rest of the chains are fit back into their original positions
    • Before you get back on your bike, shift to the lowest gear and continue pedaling. This movement should realign your chain and lock it back into place.
  4. Bike Chain Replacement, Reminder: 步骤 5 中的图像 1,1
    • Changing gears without pedaling can cause the chain to bind up, and should be avoided.
结论
Camara Dylan
于11/13/23注册
121 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 19
总计 291
