跳转到主内容
Bicycle chainring replacement
你所需要的
  1. Bicycle chainring replacement, Chainring: 步骤 1 中的图像 1,1
    • Unscrew both nuts on opposite sides of the rear wheel with the 15 mm wrench until the wheel loosens from the bike frame.
    • Loosen the nuts with the 15 mm wrench and continue unscrewing the nuts with your hands.
    • Push the rear wheel forward until enough slack is given on the chain.
  2. Bicycle chainring replacement: 步骤 2 中的图像 1,2 Bicycle chainring replacement: 步骤 2 中的图像 2,2
    • With the slack previously made, remove the chain off the chainring.
    • Touching the chain isn't dangerous, but it will be dirty.
  3. Bicycle chainring replacement: 步骤 3 中的图像 1,2 Bicycle chainring replacement: 步骤 3 中的图像 2,2
    • Locate chainring, the gear connected to the pedals.
    • Place the spanner tool on the backside of the 6.5 mm chainring bolt. The spanner will be used to keep the bolts in place while unscrewing them on the opposite sides.
    • On the chainring there will be one bolt facing the opposite direction, usually the bolt blocked by the pedal. Adjust for this by swapping use of the hex key and spanner tool.
  4. Bicycle chainring replacement: 步骤 4 中的图像 1,1
    • With the spanner tool on one side of the chainring, use a 5 mm hex key to remove the chainring bolts on the opposite side.
    • Repeat with the rest of the bolts.
  5. Bicycle chainring replacement: 步骤 5 中的图像 1,1
    • Use clean paper towels to wipe off the chainring bolts. Make sure to wipe off all the dirt and grease you can.
    • Clean thoroughly within the threads.
  6. Bicycle chainring replacement: 步骤 6 中的图像 1,1
    • Now that the chainring bolts are clean, apply a pea-sized amount of grease to each bolt.
  7. Bicycle chainring replacement: 步骤 7 中的图像 1,1
    • Use your fingers to evenly spread a coat the grease around the entire bolt.
    • If the chainring bolts contain rust, it is recommended to replace the bolts with a new set.
结论
6等其他人完成本指南。
Jeffrey Tang
于02/24/15注册
391 声望
撰写一个指南
团队
Cal Poly, Team 23-5, Green Winter 2015 Cal Poly, Team 23-5, Green Winter 2015 的会员
CPSU-GREEN-W15S23G5
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 17
总计 2,934
