跳转到主内容
Bicycle Handlebar Tape Replacement
你所需要的
  1. Bicycle Handlebar Tape Replacement, Handlebar Tape: 步骤 1 中的图像 1,3 Bicycle Handlebar Tape Replacement, Handlebar Tape: 步骤 1 中的图像 2,3 Bicycle Handlebar Tape Replacement, Handlebar Tape: 步骤 1 中的图像 3,3
    • Undo the brake cables holding the brake calipers under tension.
    • Depress the brake/shift levers (brifters) and insert a 5mm Allen key into the internal bolt. This bolt secures the brifters to the handlebar.
    • With the 5mm Allen key, loosen and temporarily remove brifters.
  2. Bicycle Handlebar Tape Replacement: 步骤 2 中的图像 1,3 Bicycle Handlebar Tape Replacement: 步骤 2 中的图像 2,3 Bicycle Handlebar Tape Replacement: 步骤 2 中的图像 3,3
    • Remove the old tape and discard.
    • Pour some rubbing alcohol on the rag and clean any old adhesive residue off the handlebar.
  3. Bicycle Handlebar Tape Replacement: 步骤 3 中的图像 1,3 Bicycle Handlebar Tape Replacement: 步骤 3 中的图像 2,3 Bicycle Handlebar Tape Replacement: 步骤 3 中的图像 3,3
    • Starting on the right side of the handlebar, wrap the new tape around the end in a clockwise direction moving inward.
    • Be sure to wrap the tape tight, but don't pull so hard that it rips!
    • Using the scissors, cut the tape at an angle towards the outside of the bar.
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured here)
  4. Bicycle Handlebar Tape Replacement: 步骤 4 中的图像 1,3 Bicycle Handlebar Tape Replacement: 步骤 4 中的图像 2,3 Bicycle Handlebar Tape Replacement: 步骤 4 中的图像 3,3
    • On the left side of the handlebar, wrap the tape around the end in a counter-clockwise direction moving inward.
    • Wrap tight, but don't rip!
    • Wrap the loose end with either electrical tape or the adhesive piece provided with the handlebar tape (pictured).
  5. Bicycle Handlebar Tape Replacement: 步骤 5 中的图像 1,2 Bicycle Handlebar Tape Replacement: 步骤 5 中的图像 2,2
    • Using the 5mm Allen key, reattach and tighten the brifter levers onto the handlebar.
  6. Bicycle Handlebar Tape Replacement: 步骤 6 中的图像 1,2 Bicycle Handlebar Tape Replacement: 步骤 6 中的图像 2,2
    • Reattach the brake cables to the brifters and brake calipers
    • Depress the brake levers a couple of times to test and confirm that the cables were reinstalled properly before riding.
终点
另外一个人完成了本指南。
Jordan Byrnes
于05/05/17注册
132 声望
撰写一个指南
团队
UC Davis, Team S1-G70, Coad Spring 2017 UC Davis, Team S1-G70, Coad Spring 2017 的会员
UCD-COAD-S17S1G70
3 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 17
总计 565
