跳转到主内容
加入维修社区 - 创建账户
Bicycle Freewheel Replacement
你所需要的
  1. Bicycle Freewheel Replacement, Freewheel: 步骤 1 中的图像 1,3 Bicycle Freewheel Replacement, Freewheel: 步骤 1 中的图像 2,3 Bicycle Freewheel Replacement, Freewheel: 步骤 1 中的图像 3,3
    • Before you begin, remove the rear wheel from your bike.
    • Place the freewheel removal tool onto the notches of the freewheel.
  2. Bicycle Freewheel Replacement: 步骤 2 中的图像 1,1
    • Use an adjustable wrench to turn the freewheel removal tool counter-clockwise to loosen the freewheel.
  3. Bicycle Freewheel Replacement: 步骤 3 中的图像 1,3 Bicycle Freewheel Replacement: 步骤 3 中的图像 2,3 Bicycle Freewheel Replacement: 步骤 3 中的图像 3,3
    • When it's loose, remove the freewheel by hand.
  4. Bicycle Freewheel Replacement: 步骤 4 中的图像 1,1
    • Carefully examine the hub threads for any signs of damage or wear, such as cross-threading or debris.
    • Before installing the new freewheel, apply a light coat of grease or anti-seize lubricant to prevent future issues and ensure smooth installation.
  5. Bicycle Freewheel Replacement: 步骤 5 中的图像 1,2 Bicycle Freewheel Replacement: 步骤 5 中的图像 2,2
    • Install the new freewheel by spinning it with your hand clockwise until it is snug.
    • You should not feel any tension as this is a sign of cross-threading.
结论
After following this guide your new freewheel should be installed.
David Hanna
于01/09/25注册
122 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 18
过去 30 天: 81
总计 614
