跳转到主内容
加入维修社区 - 创建账户
Bi-Fold Door Track Replacement
你所需要的
  1. Bi-Fold Door Track Replacement, Bi-Fold Door Track: 步骤 1 中的图像 1,3 Bi-Fold Door Track Replacement, Bi-Fold Door Track: 步骤 1 中的图像 2,3 Bi-Fold Door Track Replacement, Bi-Fold Door Track: 步骤 1 中的图像 3,3
    • If applicable, remove existing doors from the track to provide an open closet space.
    • When detaching the door from the base of the brackets, remove each pivot one at a time. Typically, there is a wheel and a pivot.
    • Remove the wheel from the track by pushing down on the wheel and pulling the door away from the track.
    • Remove the pivot by pushing downwards into the door and then pulling the door out of the track towards you.
  2. Bi-Fold Door Track Replacement: 步骤 2 中的图像 1,2 Bi-Fold Door Track Replacement: 步骤 2 中的图像 2,2
    • Use the electric drill to remove all screws from the existing track to separate the track from the header of the closet.
    • There are three screws on the track: two 1 1/2 in screws and one 3/4 in screw.
  3. Bi-Fold Door Track Replacement: 步骤 3 中的图像 1,3 Bi-Fold Door Track Replacement: 步骤 3 中的图像 2,3 Bi-Fold Door Track Replacement: 步骤 3 中的图像 3,3
    • The door track should sit in the middle of the header of the closet with equal measurements on both sides. This is an example of what the track should look like when positioned correctly.
    • Use the tape measure to find the middle point of the closet lining for placement. Using your pencil, mark where the middle checkpoint is.
    • You can use the tape measure again to ensure that there is the same amount of space on both sides.
  4. Bi-Fold Door Track Replacement: 步骤 4 中的图像 1,2 Bi-Fold Door Track Replacement: 步骤 4 中的图像 2,2
    • Place the new track against the center of the header making sure it is lined up with the middle mark from previous step.
    • Use two hands for the next step for safety. Use one hand to hold the track in place and the other to hold the drill still in prep for drill work.
  5. Bi-Fold Door Track Replacement: 步骤 5 中的图像 1,3 Bi-Fold Door Track Replacement: 步骤 5 中的图像 2,3 Bi-Fold Door Track Replacement: 步骤 5 中的图像 3,3
    • Drill in the 1 1/2 inch screws to connect the track with the header.
    • Drill in the 3/4 inch screw at the first hole on the track.
  6. Bi-Fold Door Track Replacement: 步骤 6 中的图像 1,3 Bi-Fold Door Track Replacement: 步骤 6 中的图像 2,3 Bi-Fold Door Track Replacement: 步骤 6 中的图像 3,3
    • Slide the bracket into its proper position at the end of the track.
    • Tighten the bracket using the drill to lock the bracket into place.
    • The bracket should stay in place and no longer be able to slide.
  7. Bi-Fold Door Track Replacement: 步骤 7 中的图像 1,3 Bi-Fold Door Track Replacement: 步骤 7 中的图像 2,3 Bi-Fold Door Track Replacement: 步骤 7 中的图像 3,3
    • Reattach the doors into the new track according to the proper pivots, one at a time.
    • Push down the main pivot and angle it into the track to put it into place. When in place, let go of the pivot to lock the door in place.
    • Bring the second panel of the door towards the track. Once met at the track, push down on the wheel and insert it into the track and let go.
终点
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 42
过去 30 天: 169
总计 2,454
