跳转到主内容
Beyblade Burst Gear Replacement
你所需要的
  1. Beyblade Burst Gear Replacement, Gear: 步骤 1 中的图像 1,1
    • Here is all the materials you need. The launcher needed the replacement of a gear and a gear and a screwdriver to gain access to the Broken gear.
  2. Beyblade Burst Gear Replacement: 步骤 2 中的图像 1,1
    • Unscrew the screw that located on the launcher. The screws are placed within the divots.
  3. Beyblade Burst Gear Replacement: 步骤 3 中的图像 1,1
    • Gently separate the two halves open the launcher and locate the problem gear.
  4. Beyblade Burst Gear Replacement: 步骤 4 中的图像 1,1
    • Remove old gear and replace it with the new gear. Make sure the gears line up by spinning the top gear and watching to make sure the second gear also moves.
  5. Beyblade Burst Gear Replacement: 步骤 5 中的图像 1,1
    • Put the two pieces back together. I recommend putting the gear side down and putting the top side on top to ensure no movement from the gear. Once you but the two haves together flip the launcher on its back and get ready to put back the screws.
  6. Beyblade Burst Gear Replacement: 步骤 6 中的图像 1,1
    • Screw each screw back into each hole. After making sure the launcher is held tightly together launch a beyblade to ensure the launcher and gear is working properly.
结论
Travis
于01/21/25注册
133 声望
撰写一个指南
团队
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 20
总计 133
