跳转到主内容
Betty Crocker Hot Pot BC-1762 Disassembly
你所需要的
  1. Betty Crocker Hot Pot BC-1762 Disassembly, Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 1 中的图像 1,2 Betty Crocker Hot Pot BC-1762 Disassembly, Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 1 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove the main 24 mm screw, washer, and black stopper located at the bottom of the Hot Pot.
  2. Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 2 中的图像 1,2 Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 2 中的图像 2,2
    • Pop off the dial that controls the heat setting.
  3. Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 3 中的图像 1,1
    • Remove the bottom section by sliding the dial bar backwards and out.
  4. Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 4 中的图像 1,2 Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 4 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the two 13 mm screws and small metal bar that hold the two thick white wires in place.
    • These two wires combine to connect to the power cord on the outside of the device.
  5. Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 5 中的图像 1,2 Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 5 中的图像 2,2
    • Use the Phillips #1 screwdriver to remove:
    • the transparent red block
    • 11 mm screw and small washer
  6. Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 6 中的图像 1,1
    • Detach the raised metal portion by removing the 15 mm screw and washer using a Phillips #1 screwdriver.
  7. Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 7 中的图像 1,3 Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 7 中的图像 2,3 Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 7 中的图像 3,3
    • Use the Phillips #1 screwdriver to remove the four 10 mm screws and washers that hold the cross section of metal in place.
  8. Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 8 中的图像 1,3 Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 8 中的图像 2,3 Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 8 中的图像 3,3
    • Remove the last 10 mm screw and thin metal bar that are located under where the large metal plate was (put your back into it).
  9. Betty Crocker Hot Pot BC-1762 Disassembly: 步骤 9 中的图像 1,1
    • Device Schematic
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 14
总计 225
