跳转到主内容
Besta Super 5000 Motherboard Replacement
你所需要的
  1. Besta Super 5000 Motherboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device over so that the barcode is facing upwards.
  2. Besta Super 5000 Motherboard Replacement: 步骤 2 中的图像 1,2 Besta Super 5000 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Place your fingers on the battery cover arrow and pull the cover down and off the device.
  3. Besta Super 5000 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Pull upwards on the battery tab to remove the battery from the device.
  4. Besta Super 5000 Motherboard Replacement, Back Cover: 步骤 4 中的图像 1,1
    • Remove the five screws around the edge of the device using a Phillips #0 screwdriver.
  5. Besta Super 5000 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the two screws behind the battery using a Phillips #0 screwdriver.
  6. Besta Super 5000 Motherboard Replacement: 步骤 6 中的图像 1,2 Besta Super 5000 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the device with screws still in it because you may damage it.
    • Gently pry off the backing using an opening tool.
  7. Besta Super 5000 Motherboard Replacement, Motherboard: 步骤 7 中的图像 1,1
    • Remove the three silver screws from the black round battery using a Phillips #0 screwdriver.
  8. Besta Super 5000 Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the five small screws from the motherboard using a Phillips #0 screwdriver.
  9. Besta Super 5000 Motherboard Replacement: 步骤 9 中的图像 1,3 Besta Super 5000 Motherboard Replacement: 步骤 9 中的图像 2,3 Besta Super 5000 Motherboard Replacement: 步骤 9 中的图像 3,3
    • Using a pair of tweezers, pinch the center of the yellow ribbon located in the corner of the device.
    • Potential for device damage: Do not yank or remove the ribbon from the device.
    • Carefully pull the hidden piece of yellow ribbon out from underneath the motherboard.
  10. Besta Super 5000 Motherboard Replacement: 步骤 10 中的图像 1,2 Besta Super 5000 Motherboard Replacement: 步骤 10 中的图像 2,2
    • Potential for device damage: All screws must be removed before you begin this step. Do not forcefully pry apart the motherboard with screws still in it because you may damage it.
    • Carefully pry off the motherboard with an opening tool.
  11. Besta Super 5000 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Take the motherboard out of the body frame.
  12. Besta Super 5000 Motherboard Replacement: 步骤 12 中的图像 1,2 Besta Super 5000 Motherboard Replacement: 步骤 12 中的图像 2,2
    • Lift the black keyboard mat off of the motherboard.
    • Replace the motherboard.
结论
另外一个人完成了本指南。
Jessie
于09/30/14注册
370 声望
创作了3篇指南
团队
Ohio State, Team 1-5, Buehl Fall 2014 Ohio State, Team 1-5, Buehl Fall 2014 的会员
OSU-BUEHL-F14S1G5
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 331
