跳转到主内容
Bendix Magneto Rough Coil Replacement
你所需要的
  1. Bendix Magneto Rough Coil Replacement, Rough coil: 步骤 1 中的图像 1,1
    • Use a #2 Flathead screw driver to remove the five screws on the body of the magneto, indicated by the red circles.
  2. Bendix Magneto Rough Coil Replacement: 步骤 2 中的图像 1,1
    • Locate the two screws on the right and left side of the primary circuit.
    • Remove the screws using a #2 Flathead screw driver.
  3. Bendix Magneto Rough Coil Replacement: 步骤 3 中的图像 1,1
    • Remove the primary circuit and replace it.
    • The super coil may seem as though it will not come out, but it does. It can just get a little jammed.
结论
3等其他人完成本指南。
Kelsi English
于09/26/12注册
501 声望
创作了5篇指南
团队
Cal Poly, Team 1-2, Propen Fall 2012 Cal Poly, Team 1-2, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G2
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 19
总计 2,974
