跳转到主内容
加入维修社区 - 创建账户
Benchmade Griptillian Disassembly
你所需要的
  1. Benchmade Griptillian Disassembly, Close the blade and turn the knife to the side that has the belt clip: 步骤 1 中的图像 1,1
    • Be sure to make note of what side the belt clip is on for reassembly.
  2. Benchmade Griptillian Disassembly, Remove screws: 步骤 2 中的图像 1,1
    • Use a T6 bit to remove the two screws holding the belt clip.
  3. Benchmade Griptillian Disassembly, Remove T6 Screws: 步骤 3 中的图像 1,1
    • Use the T6 bit to remove the four screws holding the handle in place.
  4. Benchmade Griptillian Disassembly, Turn the knife over: 步骤 4 中的图像 1,1
    • Turn the knife over and remove one T6 screw.
  5. Benchmade Griptillian Disassembly, Remove the T8 screw: 步骤 5 中的图像 1,1
    • Turn the knife over and remove the T8 screw that is going through the hinge.
  6. Benchmade Griptillian Disassembly, Remove the handle: 步骤 6 中的图像 1,1
    • Once you've removed the screw, you can remove the handle.
  7. Benchmade Griptillian Disassembly, Drive pin out of the other handle: 步骤 7 中的图像 1,1
    • Using the T6 bit, drive the hinge pin out of the other handle.
  8. Benchmade Griptillian Disassembly, Remove the other handle: 步骤 8 中的图像 1,1
    • Once you've done this you can remove the other handle.
  9. Benchmade Griptillian Disassembly, Slide the blade out of the frame: 步骤 9 中的图像 1,1
    • Be sure to keep both brass washers. Sometimes they will stick to the frame or the blade.
  10. Benchmade Griptillian Disassembly, Sand both sides of copper: 步骤 10 中的图像 1,1
    • Using 600 grit sandpaper and a flat surface, rub both sides of the copper washers until there is new material showing.
  11. Benchmade Griptillian Disassembly, Reverse process to re assemble: 步骤 11 中的图像 1,1
    • Reverse process to re assemble.
结论
3等其他人完成本指南。
Spin Modder
于07/21/22注册
256 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 13
过去 30 天: 54
总计 1,113
