跳转到主内容
BenQ HT1075 Projector Circuit Board Replacement
你所需要的
  1. BenQ HT1075 Projector Circuit Board Replacement, Lamp: 步骤 1 中的图像 1,1
    • Loosen the 2.5 mm Phillips #1 screw that holds the top assembly in place using a Philips #1 (PH1) screwdriver. This will enable you to lift and slide off the top cover.
    • Fully remove the top cover in order to get to the lamp housing.
  2. BenQ HT1075 Projector Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Carefully peel off the adhesive film covering the lamp housing.
  3. BenQ HT1075 Projector Circuit Board Replacement: 步骤 3 中的图像 1,1
    • Using a Phillips #1 (PH1) screwdriver, loosen and remove the single 2.5 mm Phillips #1 screw that secures the lamp housing to the projector.
  4. BenQ HT1075 Projector Circuit Board Replacement: 步骤 4 中的图像 1,1
    • Remove the lamp from the projector by pulling on the lamp handle.
    • Apply more force on the side opposite of the newly removed screw as you pull the lamp out.
  5. BenQ HT1075 Projector Circuit Board Replacement, Circuit Board: 步骤 5 中的图像 1,1
    • Turn the projector over and remove the five 9.5 mm Phillips #1 screws that hold the back cover with a Phillips #1 (PH1) screwdriver.
  6. BenQ HT1075 Projector Circuit Board Replacement, Remove the 6th screw holding the top cover: 步骤 6 中的图像 1,1
    • Flip the projector and remove the 6th and last crew.
  7. BenQ HT1075 Projector Circuit Board Replacement: 步骤 7 中的图像 1,1
    • Using an opening tool, remove the top cover by first loosening its top cover.
  8. BenQ HT1075 Projector Circuit Board Replacement: 步骤 8 中的图像 1,2 BenQ HT1075 Projector Circuit Board Replacement: 步骤 8 中的图像 2,2
    • Unplug the wire that connects the front cover to the circuit board.
    • Now use the opening tool to pry the front cover from the platform.
    • Gently pull the top cover from the rest of the frame.
  9. BenQ HT1075 Projector Circuit Board Replacement: 步骤 9 中的图像 1,2 BenQ HT1075 Projector Circuit Board Replacement: 步骤 9 中的图像 2,2
    • To prevent potential for electrical damage, disconnect any wires connected to the circuit board.
    • Using the opening tool, loosen the sides of the platform. Then gently pull them off from the projector components.
  10. BenQ HT1075 Projector Circuit Board Replacement: 步骤 10 中的图像 1,3 BenQ HT1075 Projector Circuit Board Replacement: 步骤 10 中的图像 2,3 BenQ HT1075 Projector Circuit Board Replacement: 步骤 10 中的图像 3,3
    • Remove these four 8.5 mm Phillips #1 screws using a Phillips #1 (PH1) screwdriver.
    • Afterwards, use a 5mm nut driver to remove the four remaining screws.
    • Use the opening tool to loosen the back cover then pull it off.
  11. BenQ HT1075 Projector Circuit Board Replacement: 步骤 11 中的图像 1,1
    • With a Phillips #1 (PH1) screwdriver, remove the four 6.3 mm Phillips screws that hold the metal casing on top of the circuit board.
    • Remove the metal casing.
  12. BenQ HT1075 Projector Circuit Board Replacement: 步骤 12 中的图像 1,2 BenQ HT1075 Projector Circuit Board Replacement: 步骤 12 中的图像 2,2
    • Using the Phillips #1 (PH1) screwdriver, remove the three 6.3 mm Phillips #1 screws holding down the circuit board.
    • Carefully pull the circuit board from the frame, adding force to the area where the pushbuttons are located.
结论
3等其他人完成本指南。
Gabriela Remulla
于09/26/17注册
1,008 声望
创作了5篇指南
团队
Cal Poly, Team S6-G1, Banghart Fall 2017 Cal Poly, Team S6-G1, Banghart Fall 2017 的会员
CPSU-BANGHART-F17S6G1
5 名成员
创作了9篇指南
2指南评论
miss i need to get some information regarding this projector repair. if you can email me, sandarukbio@gmail.com
sandarukbio92 - 回复
very good instructions and pictures thank you for your detailed work
Quinn Griffith - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 29
总计 2,628
